ACL on SVI
ciscoenginner79
Hi Guys.
i have issue with ACL on SVI. i know it was many times but pls help me on my exaple to better understand.
I have three vlans
10 Sales
20 Accouting
30 Marketing
Before applied ACL on SVI could ping all end devices. then:
appied ACL
ip access-list extended PERMIT_SALES_MARKETING
permit ip 172.16.1.0 0.0.0.255 172.16.3.0 0.0.0.255
on
interface Vlan10
ip address 172.16.1.100 255.255.255.0
ip access-group PERMIT_SAL_MAR in
Worked as it shuld be
then :
applied next ACL
ip access-list extended PERMIT_ACC_SAL_MAR
 permit ip 172.16.2.0 0.0.0.255 172.16.1.0 0.0.0.255
 permit ip 172.16.2.0 0.0.0.255 172.16.3.0 0.0.0.255
on
interface Vlan20
 ip address 172.16.2.100 255.255.255.0
 ip access-group PERMIT_ACC_SAL_MAR out
and when i tried to ping end devices on vlan 20 i had
request time out.
Thanks for help
Hello
@ciscoenginner79 wrote:
Hi Paul. You right. But is chance to allow vlan 20 reach vlan 10 but no vlan 10 to vlan 20.
So in that case you need to amend your RACLS
Try this if applicable to you
no ip access-list extended PERMIT_SALES_MARKETING
permit ip 172.16.3.0 0.0.0.255 any
permit ip 172.16.2.0 0.0.0.255 any
interface Vlan10
no ip access-group PERMIT_SAL_MAR in
ip access-group PERMIT_SAL_MAR OUT
no ip access-list extended PERMIT_ACC_SAL_MAR
permit tcp 172.16.1.0 0.0.0.255 any  established  (note only allow tcp connections)
deny tcp 192.168.1.0 0.0.0.255 any
interface Vlan20
no ip access-group PERMIT_ACC_SAL_MAR IN
ip access-group PERMIT_ACC_SAL_MAR OUT
res
Paul
Kind Regards
Paul
23 Replies 23
From where are you pinging the end devices on Vlan 20, that is, what is your source IP address ?
Hi I ping from vlan 20 ip 172.16.2.11 to vlan 10 172.16.1.10.
Before applied second acl ping was ok
Just to be sure, are you trying to apply both ACLs at the same time ? You can only apply one ACL inbound and one ACL outbound on the same interface.
To avoid confusion, can you post the full configuration of your device ?
One acl is on vlan 10 on one on vlan 20
the cofiguration is:
Current configuration : 2148 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
ip routing
spanning-tree mode pvst
spanning-tree vlan 20 priority 24576
spanning-tree vlan 10 priority 28672
interface FastEthernet0/1
 channel-group 1 mode on
 switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Port-channel 1
interface Vlan1
 no ip address
 shutdown
interface Vlan10
interface Vlan20
 ip access-group PERMIT_ACC_SAL_MAR in
interface Vlan30
 ip address 172.16.3.100 255.255.255.0
interface Vlan100
 ip address 192.168.1.110 255.255.255.0
ip classless
line con 0
line aux 0
line vty 0 4
 login
end
Julio E. Moisa
It should be in
ip access-group PERMIT_ACC_SAL_MAR out  <---- in instead out.
ICMP is reciprocal, it works in 2 ways, modify that and please try again
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
hi changed on in and resoult this same request time out
ok can you apply this ACL and try again
access-list 100 permit ip any any
inter vlan 10
ip access-group 100 out
inter vlan 20
or try with instead ip any any:
access-list 100 permit icmp any any
access-list 100 permit icmp any any echo
access-list 100 permit icmp any any echo-reply
it works but i want to:
vlan10 access to vlan 30 only.
vlan20 access to vlan 10 and 30
vlan30 access to vlan 10 only.
I will send you configuration:
Current configuration : 2118 bytes
version 12.2
hostname Switch
ip routing
interface Vlan1
 no ip address
 shutdown
interface Vlan10
interface Vlan20
interface Vlan30
interface Vlan100
ip classless
line con 0
line aux 0
line vty 0 4
 login
end
Ok for example, remove the ACL 100 from the SVI 10 it should be:
ip access-list extended PERMIT_MARKETING_SALES
permit ip 172.16.3.0 0.0.0.255 172.16.1.0 0.0.0.255
int vlan 10
ip access-group PERMIT_SALES_MARKETING in
ip access-group PERMIT_MARKETING_SALES  out
nt vlan 30
ip access-group PERMIT_SALES_MARKETING out
ip access-group PERMIT_MARKETING_SALES  in
Test communication between vlan 10 and 30
Hi ping it fails
Please try again including these lines:
 permit icmp 172.16.1.0 0.0.0.255 172.16.3.0 0.0.0.255
permit icmp 172.16.3.0 0.0.0.255 172.16.1.0 0.0.0.255
i recreated your setup, and the access lists seem to work. That said, have a look at your configuration. It looks like you are applying a non-existent access list to interface Vlan 10...or is this a type
interface Vlan10
interface Vlan20
interface Vlan30
interface Vlan100
ping from vlan 30 to valn 10 block by acl destination host unreachable
from vlan 10 to 30 request time out
