Acl on vlan interface question
dcarr3311
Level 2
Level 2
I'm a bit confused about the directon of ACL's on Vlan intervaces
I'm trying to deny vlan 301  from accesing any ip's on vlan 302 does this make sence?
interface Vlan301
description wireless users
ip address 192.168.177.126 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan302
description Training
ip address 192.168.177.190 255.255.255.192
ip access-group wireless_restirct out
no ip redirects
no ip unreachables
no ip proxy-arp
ip access-list extended wireless_restrict
deny   ip 192.168.177.0 0.0.0.127 any log
permit ip any any
2 Accepted Solutions
Edison Ortiz
That should work - just tried in the lab. BTW, remove the log keyword - it's not supported on catalyst switches.
ip access-list extended CISCO
deny   ip 10.2.129.0 0.0.0.255 any
permit ip any any
interface Vlan1
ip address 10.2.129.250 255.255.255.0
no ip redirects
interface Vlan100
ip address 192.168.100.2 255.255.255.0
ip access-group CISCO out
Extended IP access list CISCO
    10 deny ip 10.2.129.0 0.0.0.255 any (20 matches)
    20 permit ip any any
ping 10.2.129.5
Sending 5, 100-byte ICMP Echos to 10.2.129.5, timeout is 2 seconds:
    10 deny ip 10.2.129.0 0.0.0.255 any (25 matches)
John Blakley
In edition to Edison's response, the easiest way that I remembered in/out directions was by subnet. If you're on the vlan 301, you subnet is going to be 192.168.177.0/25. If you have a user that's addressed in that range, their source is going to be 192.168.177.0/25 going to . You can deny inbound on that vlan matching that source:
access-list 101 deny ip 192.168.177.0 0.0.0.127 192.168.177.64 0.0.0.63
access-list 101 permit ip any any
inter vlan 301
ip access-group 101 in
The addresses on the subnet that use vlan 301 as a gateway will go IN to the svi...any svi that they come OUT of would be in the out direction.
John
HTH, John *** Please rate all useful posts ***
Edison Ortiz
permit ip any any
interface Vlan1
no ip redirects
interface Vlan100
ping 10.2.129.5
John Blakley
inter vlan 301
John
thanks guys!
