ACL query and dhcp
jcrow
A simple query regarding Access Control Lists and dhcp.
192.168.1.2 is the dhcp server.
Say I have a vlan 101 configured with the following:
 ip access group TEST_IN in
 ip access group TEST_OUT out
 ip helper-address 192.168.1.2
Here are the ACL's themselves:
ip access-list extended TEST_IN
 permit udp any host 192.168.1.2 eq bootps
ip access-list extended TEST_OUT
 deny ip any any
In the above would a client connected via the 101 vlan be able to get an IP address via dhcp?  It could send the dhcp request but would 'deny ip any any' block the return packets?
Or are the packets allowed because the router acts as a relay for the dhcp server (via ip helper-address) and the router itself allows the return packets regardless of the ACL's?
cheers
jcrow
Yes, It will block.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
7 Replies 7
Jon Marshall
The acl needs to allow the packets before the router can forward the DHCP request.
Note though that you have the direction on your acl wrong ie. inbound is traffic from clients in vlan 101 so the source IP would never be the DHCP server.
Jon
Thanks for the response.
The clients in vlan 101 can initiate a dhcp request via the following:
What I am asking is if the dhcp servers response would be blocked by the out acl:
deny ip any any
Yes, It will block.
Deepak Kumar
Deepak Kumar,
It will block, thanks Deepak.
After some more investigation I could allow responses from the dhcp server by either explicitly permitting on the out acl or a simpler method is applying an ip inspect for the various protocols.
I have just tested this in a lab and it did not block the IP address assignment.
The lab was using virtual routers but I suspect the same would be seen with real equipment.
Jon
Deepak
Do you know this for a fact because my test has just shown otherwise but it could be because I am not using real equipment.
Jon
Yes, sorry I misread your acl, it is correct as you say.
As for being blocked on the way back it is a good question because traffic generated by the router itself bypasses any acls and the response is actually generated by the router after it has received a reply from the DHCP server.
To be honest don't know without testing.
Jon
