ACL should apply in where
2 Accepted Solutions
I think your configuration should be on the port (could be connected to the ISP router) which is used for traffic going out to your ISP:
interface GOINGOUT0/1
ip access-group DENY out
ip access-list extended DENY
permit ip host 10.51.165.180 host 10.104.101.60
permit ip host 10.51.165.181 host 10.104.101.60
permit ip host 10.51.165.182 host 10.104.101.60
permit ip host 10.51.165.183 host 10.104.101.60
permit ip host 10.51.165.184 host 10.104.101.60
deny ip any host 10.104.101.60
permit ip any any
If you take the acl I gave to you it will be applied with IN on the svi of your server host.
The acl should be adapted based on if you apply IN or OUT.
OUT --> Traffic TO the vlan
IN --> Traffic going away FROM the vlan
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
14 Replies 14
Francesco Molino
You want to deny every subnets to reach your host 10.104.101.60 except the 5 IPs you gave.
Let's assume your host 10.104.101.60 belongs to vlan 101
I would suggest to create an ACL and attach that ACL on SVI 101:
 permit ip host 10.104.101.60 host 10.51.165.180
 permit ip host 10.104.101.60 host 10.51.165.181
 permit ip host 10.104.101.60 host 10.51.165.182
 permit ip host 10.104.101.60 host 10.51.165.183
 permit ip host 10.104.101.60 host 10.51.165.184
 deny   ip host 10.104.101.60 any
int vlan 101
 ip access-group DENY in
Francesco
where is 10.104.101.60 ? Is that part of a VLAN as well ? If so, apply the access list outbound on the interface 10.104.101.60 is connected to...
10.104.101.60 is not part of the VLAN in my LAN, it is in different country already.
Ok then apply the ACL on the interface that routes traffic outside of your network.
Is it a L2L VPN?
Francesco
it is not VPN, it is to other ISP router via MPLS line.
should i apply the ACL on that SVI that directly connect to the ISP router ?
does below ACL still valid in apply to this SVI?
deny ip 10.51.165.0 0.0.0.255 any ********** i'm not to sure of this, will it work, then next is permit all
permit ip any any
permit ip any any
I added this line deny ip 10.51.165.0 0.0.0.255 any ********** because you wanted to deny other hosts from this subnet to access the network 10.104.101.0/24.
Indeed, after reading your first post you want to deny any subnets to access host 10.104.101.60.
Then the new line instead of that one will be:
Francesco
Hello
Possibly create two acls and apply them accordingly.
vlan 1650
ip access-list extended TEST1
permit ip any any
int vlan 1650
ip access-group TEST1 OUT
other vlans
ip access-list extended TEST2
permit ip any any
int vlan xx
ip access-group TEST2 OUT
res
Paul
Kind Regards
Paul
Paul,
I have more that 10 VLAN, I don't want to add ACL on every interface VLAN
Hello
Just realized is this host is external to your LAN?
If so you could apply an acl on the wan interface to negate  access by this host.
permit ip any any
int xxx
description WAN
ip access-group TEST IN
res
Paul
Kind Regards
Paul
Francesco
Hello
I guess that would be correct for RACL applied to SVIs but not for routed interfaces
Res
Paul
Kind Regards
Paul
Hello
IN - ingress - inwards from outside network
OUT - egress - outwards from inside network
Think of a door to a room and your stood their allowing people in or out
IN = allow them in
OUT = allow them out
Res
Paul
Kind Regards
Paul
