ACL
jonk34567
Level 6
Level 6
1.# access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 23 11.1.1.0 0.0.0.255
                               vs
2.# access-list 101 permit tcp 10.1.1.0 0.0.0.255 11.1.1.0 0.0.0.255  eq 23
is there any diffrence between first and secound command ?
Julio E. Moisa
Yes there is a difference:
The ACL #1 is representing the traffic generated (sourced) by the network 10.1.1.0/24 and using the port 23 (telnet) as source port to reach the network 11.1.1.0/24
The ACL #2 is telling you: allow the network 10.1.1.0/24 (source) reach the network 11.1.1.0/24 (destination) with port 23 (telnet) destination port.
The sintaxis of an extended ACL is:
access-list <ACL ID> permit/deny <protocol> <source network/host> <wildcard> <source port / range of ports> <destination network/host> <wildcard><destination port / range of ports>.
Usually the computer use dynamic port so you can exclude the source port, now the source port is usually used by servers when they are sending a response to a specific source.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
Hope it is useful
