Add another ethernet interface for more Bandwidth
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-01-2013 05:40 AM - edited 03-07-2019 04:22 PM
I had a question about our ASR1006, we currently have two separate gigabitethernet connections coming into our ASR1006 from Fiber from two separate providers BGP. We are running BGP and OSPF, we currently only have one Ethernet connection coming from the ASR1006 to our Core switch which goes into a VLAN (Broadcast not point to point). How can we configure another Ethernet connection over to our Core to allow more bandwidth to get to our ASR?
- Labels:
Other Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2013 06:00 AM
What is the speed on your two separate ISP connections?
The "Ethernet" connection from the ASR1006 to the core switch, is this FastEthernet or GigabitEthernet?
Are you running OSPF from your CORE to the ASR?
And are you just pushing a default route from the ASR to your core?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2013 07:14 AM
One is a 700mb burstable to 1gb
the other is 300mb burstable to 1gb
the ethernet connection is gigabitethernet from the asr to the core
Yes the ASR is an OSPF neighbor of the CORE, and we are pushing a full routing table to the Core
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2013 07:30 AM
This is going to depend one many different aspects.
SO the OSPF network type from the ASR1006 to the Core is Broadcast, if you were to add another OSPF neighbor (link from the ASR to the Core), then from the Core to the ASR1006 you will have two ospf neighbors. Since by default, they will both have the same speed (1Gbps), they will have a cost of 1, unless you changed the reference bandwidth. Anyway, by default, OSPF should load balance (Which CEF is probably doing it). This should load balance based on per-destination.
So you could theorically use the two links at the same time.
You could change the COST for specifies routes on each router, so it uses one over the other.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2013 07:46 AM
I have the gigabitethernet interface configured the same as our original connection to the core (except different ip and subnet mask- which I think may be the issues) and it is plugged into the Core, the issue arrises i believe that I have my CORE / ASR / CMTS all configured into a vlan. The new connection that I added is on a different subnet than that Vlan since I cannot put the second connection in the same subnet that overlaps with the current interface connection.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2013 08:18 AM
What ESP module do you have on the ASR?
If you connect the interface from the ASR to the core with a /30 for example, add this into OSPF, then the core should have multiple routes to all the destinations received from the ASR. By default, a 1Gbps link, should have a cost of 1, which will be added to the cost.
As long as the costs are the same, it should do equal cost load balancing, thereby allowing you to use the two links.
But since OSPF, doesn't do unequal load balancing, they will have to be the same cost.
Or, you could have half the routes with a lower metric on one interface, and the other routes have a lower cost on the other.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2013 09:02 AM
ESP20
Should I configure an Ip address on the interface in the Core or put it in a seperate Vlan?
currently I have it with no ip address and switchport accesss into a new vlan i created.
The core sees it as a neigbor and has a Full/DR Priority 1
the other connection has Full/Drother Priority 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2013 09:24 AM
Just to make sure we're on the same page..
On the core, they're are two different ports going to the ASR correct?
For Example...
gi0/0 on the core is going to gi0/0 on the ASR and gi0/1 on the core is going to gi0/1 (I know the interfaces may be different, this is just an example?
If this is correct, then you can configure both port in the same vlan, and have a broadcast network. One will be the DR and one will be the BDR. If this is the case, each port on the ASR going to the core will need an IP address.
You can also configure each in a separate vlan.
Either way, you should have equal cost routes, with a cost of most likely 1. It's going to load balance based on souce/dest hash. So you can test that out, to make sure it's working correctly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2013 09:57 AM
The costs are 1 on each, and yes there are 2 seperate gigabitethernet ports going from the ASR to the Core (each it its own Vlan). I still do not have any traffic going over the new one. Here are my interface Configs.
ASR:
router ospf 1
network x.x.x.x 0.0.0.127 area 0.0.0.1
network x.x.x.x 0.0.0.7 area 0.0.0.1
interface GigabitEthernet0/0/0 (Existing Connection to 8/1)
ip address X.X.X.X 255.255.255.128
ip flow ingress
ip ospf 1 area 0.0.0.1
negotiation auto
interface GigabitEthernet0/0/5 (New Connection to 8/4)
ip address X.X.X.X 255.255.255.248
ip flow ingress
negotiation auto
CORE:
router ospf 1
log-adjacency-changes
redistribute connected
network X.X.X.X 0.0.0.127 area 0.0.0.1
network X.X.X.X 0.0.0.7 area 0.0.0.1
default-information originate always
interface GigabitEthernet8/4 (NEW Connection)
switchport
switchport access vlan 3
switchport mode access
no ip address
spanning-tree portfast
interface GigabitEthernet8/1 (Existing Connection)
switchport
switchport access vlan 10
no ip address
interface Vlan3
no ip redirects
ip nat outside
interface Vlan10
no ip redirects
ip nat outside
Now I also have the IP of the new gige interface set us as a bgp neighbor in the Core, is this correct?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2013 10:13 AM
Now, I'm a little confused. Let's get on the same page here.
From my understanding, the BGP sessions are from the ASR to the ISP(s), and then OSPF from the ASR to the Core? Is this correct?
Because from what you said above, it sounds like you have a BGP session from the Core to the ASR?
I see the ospf config on the router, pushing out a default route to downstream ospf neighbors.
Can you post the results from 'show ip ospf neighbor' on the CORE.
Feel free to blank out any config you don't want the public to see obviously.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2013 10:31 AM
You are correct- I have removed the bgp neighbor from the core.
Neighbor ID Pri State Dead Time Address Interface
ASR1006 -ID 1 FULL/DR 00:00:36 XXXX Vlan3 -- (New Connection)
CMTS 0 FULL/DROTHER 00:00:34 XXXX Vlan10
720VXR 1 FULL/DROTHER 00:00:39 XXXX Vlan10
BACKUP CORE 1 FULL/BDR 00:00:37 XXXX Vlan10
ASR1006-ID 1 FULL/DROTHER 00:00:34 XXXX Vlan10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2013 10:49 AM
You also said that the Core switch is receiving full BGP routes from the ASR, is this correct?
Since you are running BGP from ASR to ISP(s), and OSPF from ASR to CORE, I'm assuming you have redistribution going on?
Can you post that config.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2013 11:06 AM
ASR:
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
ISP 4 xxxx 5104986 60951 25767651 0 0 5w3d 463431
ISP 2 4 xxxx 2629 2746 25767578 0 0 20:54:23 1
CORE 4 DDDD 2785 294873 25767657 0 0 1d22h 0
router bgp DDDD
bgp log-neighbor-changes
neighbor ISP 1 remote-as XXXX
neighbor ISP 2 remote-as XXXX
neighbor CORE remote-as DDDD
redistribute ospf 1 (is turned on under address-family)
CORE:
720VXR 4 DDDD 636077 635066 34043728 0 0 1d22h 89
ASR1006 4 DDDD 11173335 635095 34043728 0 0 1d22h 463442
router bgp DDDD
neighbor 720VXR remote-as DDDD
neighbor ASR1006 remote-as DDDD
Redistribute ospf 1 is not turned on under address family in core- should it be?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2013 11:14 AM
Thanks Brandon.
On the ASR, I see three BGP neighbor commands. From my understanding they're should only be 2, which go to ISP1 and ISP2. I didn't think the CORE had any BGP commands.
If this is done under address-family ipv4, you are redistributing all routes in OSPF process 1, into BGP, is this what you want to happen? With this configured, it's going to advertise your OSPF networks to your ISP(s).
From what I understand, you should have two BGP sessions on the ASR1006;
One to ISP1 and One to ISP2.
Then you will have two OSPF neighbors on the ASR1006 going to the core, and no BGP on the core.
Under 'router ospf 1' on the ASR, I would configure 'redistribute bgp
Then, on the Core, you will have ALL the BGP routes on the ASR1006 redistributed in to OSPF on the Core.
Now considering the fact that the only way for users to get to the Internet is to go to the ASR1006, I would make sure you are advertising a default route into your Core, with this, you should have two defaul routes with the same metric, and then load balancing should be performed.
Is this a live network? If so, I don't want to blow up your network, and just make usre to test things out first.
***** Understand that if you redistribute all BGP routes to OSPF, all other OSPF routers will have this as well *******
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2013 11:27 AM
I would take the following steps.
1. Get rid of he BGP going from the ASR1006 to the core
2. Verify that BGP is not configured on the core
3. Make sure they're are two OSPF neighbors on ASR1006 to the CORE
4. Verify on the Core, that they're are TWO ospf neighbors going to the ASR1006
5. On the ASR1006, I would do 'default information-originate always'
6. This will push a default route down to the Core
7. At this point, you should have two default routes with the same mask, cost, and administrative distance.
8. You should be able to load balance at this point
Of crouse, you know your network better than me, so just be careful with default routes
