add layer 3 switches to existing network
tech44048
We need to add layer 3 switch (MS-250 Meraki)  to perform intervlan
we have SAS 5506 That connect to vpn (Anyconnect) in vlan 1 ip 192.168.1.1
all connection go from this vlan 1 to the server,workstation,printer,vpn......
we need to divide our network to  intervlan 20,30 and keep vlan 1 manage our server and printer
Vlan 1 for server and printer 192.168.1.0/24(because we can not change server and printer  ips)
intervlan for workstation 192.168.20.0/24
intervlan for wifi 192.168.30.0/24
we alredy create the intervlan interface in the switch and the scope in dhcp server
Name
Subnet
IP interface
VLAN id
DHCP Settings
Mangement vlan
192.168.1.0/24
192.168.1.3
off
workstation vlan
192.168.20.0/24
192.168.20.3 20
20
Relay to dhcp server
wifi vlan
192.168.30.0/24
192.168.30.3 30
30
Dhcp server 2016 : 192.168.1.10
we create scope using the switch's routing interface for each VLAN as the gateway
192.168.1.1 for scope 1
192.168.20.3 for scope 20
192.168.30.3.for scope 30
topologie
Problem:
we start move same workstation to vlan 20 for test
Device in vlan 20 Take adress in vlan 20 , DHCP work fine , but  no internet to this device
I can not ping any address from vlan 1 when i'm using  vlan 20 or 30 to , but ping work fine between vlan 20 and 30
Questions:
1/haw we can configure our firewall (with static rout for each intervlan )?
2/just add static rout for each intervlan(20,30)?
10 Replies 10
acampbell
You need to point a default route out to the firewall interface on VLAN 1
DEST/SUBNET MASK NEXT HOP
ip route 0.0.0.0 0.0.0.0 192.168.1.1 for_DEFAULT_ROUTE_TO-ASA
On
ASA F/WALL
You need to point straic routes to the user vlans at the L£ switch VLAN 1 interface.
ip route 192.168.20.0 255.255.255.0 192.168.1.3 for_vlan_20
ip route 192.168.30.0 255.255.255.0 192.168.1.3 for_vlan_30
Regards, Alex. Please rate useful posts.
Hi Alex
by adding a default rout out of firewall
this not affected our server, printer,
we need to keep them in vlan 1 ,
Tank you
Mondher
Adding a default route will send all traffic destined for the Internet to the firewall. It does not change the vlan for any device.
Hi Reza,
how to have traffic between my Layer 3 intervlans .Vlan 20 , vlan 30 and vlan 1(native vlan)
until now my pings are succesfull between vlan 20 and 30 but unseccesful when trying to ping vlan 1(native vlan that have all my servers) from vlan 20 and 30
Thank you
If your printer & server are using the ASA as their default gateway (IE 192.168.1.1) the ASA will not send traffic back over an ingress interface.
Change the printer & server to use the L3 switch as their default gateway 192.168.1.3
You could test this with a pc or laptop in the first instance
Seasons Greetings.
Hi Alex,
Our server and printer manage by our DHCP Server(DHCP give the address to those )
in this case, we change the scope option in the DHCP server Vlan 1 from 192.168.1.1 to 192.168.1.3 ??
and add
On
ASA F/WALL
You need to point static routes to the user VLANs at the L£ switch VLAN 1 interface.
Thank you
You will need to add the route I mentioned on the L3 switch to point at the ASA
If your DHCP server is on vlan 1 using d/gateway 192.168.1.1 change that to be 192.168.1.3 (And any scope for 192.168.1.0/24 to use d/gateway 192.168.1.3 ) so that all devices use the L3 switch to route inter vlan and the L3 switch will pass any destination addresses  not in your vlans to the ASA.
Hi Alex
Thank you a lot for your help, we will test this solution, and we let you know
Hi Alex,
static rout commanded in this case ,outside or inside?
rout inside 192.168.1.20.0 255.255.255.0 192.168.1.3
or
rout outside 192.168.20.0 255.255.255.0 192.168.1.3
or both
Thank you
We want the ASA to send traffic for vlans 20 & 30 to the L3 switch so this is the ASAs "inside" network
route inside 192.168.20.0 255.255.255.0 192.168.1.3
route inside 192.168.30.0 255.255.255.0 192.168.1.3
