Boot fail cisco 2960x after firmware update gui
RonnyOlsen15669
After firmware ugrade c2960x-universalk9-tar.152-7.E3.tar done in gui my switch will not boot.
my only i
I have connected it to usb /terminal and get this output :
balaji.bandi
switch on on switch prompt
flash_init
load_helper
dir flash:  (post this output also)
if you see some .bin file, try to boot from that file
example :
boot flash:/image.bin
BB
marce1000
 - I suspect the intended firmware has not been installed fully and or correctly. Try again, and verify the md5sum when it sits on the flash.
 M.
