Adding a port in VLAN 2 and asigning an IP
imranraheel
I have a 3550 48 port switch. When ever I try to add an IP on to a port which is not a member fo any VLAN the switch gives me an error that the IP is part of VLAN 2 and when I try to add that port on Vlan2 it says
Switch1(config)#interface fastethernet 0/35
Switch1(config-if)#switchport access vlan 2
Command rejected: Fa0/35 not a switching port.
Do specify me how to configure the port in Vlan 2
18 Replies 18
ankbhasi
Hi Imran,
Issue a command "switchport" and then try your command and it should work.
Ankur
*Pls rate all helpfull post
Jon Marshall
if you want to add the port into vlan 2
switch1(config-if)# switchport
switch1(config-if)# switchport access vlan 2
Jon
After doing
Switch1(config-if)#end
I am not been able to assign IP to this port since it now becomes a L2 Port.
Is there a way to add it in to Vlan2 and assign the port IP as with different ports which are in Vlan2 having perticular IP's
Kevin Dorrell
Level 10
Level 10
Perhaps you could give us the complete show run int F0/35. Also a show int F0/35 switchport
If it is not a switching port (i.e. it is layer-3) and you want it to become so, do switchport
If it is a layer-3 port, then you should be able give it an IP address.
Or maybe the problem is that the address you are trying to give it overlaps with a range of addresses you have put on the vlan 2 routed interface. Perhaps you could tell us show run int vlan 2, and what address you are trying to put on the port.
The other possibility is that it is involved in a SPAN session. Do show monitor to verify that is not so.
Kevin Dorrell
Luxembourg
After doing
If you make it a routed ported ie "no switchport" then you cannot allocate an IP address to it out of a subnet you have already used on the switch.
So, as Kevin says, if you have allocated vlan 2 layer 3 interface an ip address you cannot then allocate another ip address from the same subnet to this routed port.
What is it you are trying to achieve ?
Jon
Basically I have connected that interface to a router and I want to assign an IP to interface where that router is connected so I can make few routers like to router data intended towards that destination connected to that router.
What is the best possible way
Either I should remove the port from VLAN 2 and assign an IP but that IP is from the same series of Vlan 2 so it gives an error that
207.XXX.XXX.XX overlaps with Vlan2 address
Do let me know the best possible way
The external router has an interface, with an IP address, right? And the hosts are also in the subnet of that IP address?
If that is the case, you don't need the layer-3 functions of the switch at all, and you don't need to configure any IP addresses on it. Just leave each port as a switchport and put them all in VLAN 2, including the one where the router is connected. As far as layer-3 is concerned, the external router will be talking directly to the hosts.
Kevin Dorrell
Luxembourg.
If you want the router interface to have an IP address from vlan 2 subnet allocate the port on the switch into vlan 2.
If you want the router interface to not have an IP address out of vlan 2 then allocate a small P2 subnet eg. 192.168.1.0/30 and
router fa0/0 192.168.1.1 255.255.255.252
switchport 192.168.1.2 255.255.255.252
The switch will need to be running ip routing for the second option to work.
Jon
There are only two architectures you can go for.
1. Have your ports in VLAN 2, in which case they are layer-2 ports. They share one IP address. (Actually, you can give them more, but then they share all of them.) In this case, you put the IP address on int vlan 2, and also any secondary addresses, but they are all shared. Forwarding between members of the VLAN are by MAC address.
2. Have your ports in layer-3 no switchport. In that case you can assign a subnet to each port, and port to port communication is via the routing element of the switch. In that case, the IP ranges may not overlap, otherwise router element does not know which one to route to. Forwarding is by IP address.
I suspect there is a more basic misunderstanding though. What are you trying to achieve?
Kevin Dorrell
Luxembourg
Switch1#show run int vlan 2
Building configuration...
Current configuration : 214 bytes
interface Vlan2
description MIXIT Client VLAN
ip address 207.xxx.xxx.xxx 255.255.255.192
no ip redirects
ip pim sparse-dense-mode
standby 1 ip 207.xxx.xxx.xxx
standby 1 priority 105
standby 1 preempt
end
Switch1#show int F0/35 switchport
Switchport: Enabled
Administrative Mode: dynamic desirable
Operational Mode: down
Administrative Trunking Encapsulation: negotiate
Negotiation of Trunking: On
Access Mode VLAN: 2 (ClientVLAN)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Above are the results you mentioned before.
Basically I want to use that Port to connect to a router So that if some request is intended towards that router IP i will add a route to pass that request from the switch port to router
# ip "router IP" "switch port IP"
No need for any IP addresses anywhere on the switch then. Just put the port where the router connects in switchport access vlan 2, and all the host machine ports as well.
Kevin Dorrell
Luxembourg
You mean i should put the IP on router insted of switch. The same Vlan2 IP so I can place that route
It's a bit difficult to see what is going on with all those X.x.x. in the IP addresses. Could you tell us the addresses - alter them to disguise them if you want, but keep the relationship between them.
What address range do your hosts have. What address is on the external router?
For example, if you external router is 172.16.22.1 255.255.255.192, then your hosts can be anything from 172.16.22.2 to 172.16.22.62. Forget about the VLAN 2 interface on the switch - just blow it away. Put all the ports in VLAN 2 as switchports, and the hosts will talk to your external router.
Kevin Dorrell
Luxembourg
