adding line card for Catalyst 6807-XL
AAbdelmaksoud
I would like to add an additional line card for the Catalyst 6807-XL, but unfortunately, EOS, is there any way to add a line card for the same chassis, how can I check the  line card compatible?
@AAbdelmaksoud wrote:
Would I be able to use Cisco Catalyst 9600 Series line cards on Cisco Catalyst 6800 Series switches?
No, it won't fit.
AAbdelmaksoud
No, it won't fit.
Leo Laohoo
Google the SKU of the line card you want to add and see where it takes you.
thanks
