CoreSwitch 6807-xl
Hi All ,
kindly your advice to factory setting for cisco core switch 6807-xl
regards,
6 Replies 6
@ahmed01005286073 check switch reset procedure in this doc.
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2900-xl-series-switches/24328-156.html
Good luck
KB
the command only with clear is # clear config lock , can not find clear config all or clear config mode rmon or all .
any advice
hI,
Try, "Write Erase". After that if you reboot the switch, it will load with no configs.
Hi , the vlans still found after use this command , also after erase all nvram still found .
Leo Laohoo
The VLAN.dat file is located in the constant-nvram: sub-directory.
I use erase /all const-nvram & /all nvram
