Adding vlan to a trunk in port channel on cat 6500 switch with CAT OS
anand ukey
Hi All,
  I need some urgent assistance with adding a vlan to the trunks bundled in port channel. I know how to add vlans to a port channel with cisco IOS but with CAT OS i'm a bit nervous.
I have 2 ports bundled to form ether channel in switch which is running CAT OS. There are already few vlans allowed in the trunk of each interface. now I need to add one more vlan.
For Example:-
vlan 135 needs to be added in addtion to the existing vlans.
clear trunk1/2 1-112,115,117-134,136-4094
set trunk 1/2 on dot1q 113-114,116,135
and similarly on the 2nd interface
so if I add vlan135 to the trunk one after another will it cause any service disruption?
Please Help.
Thanks in Advance
Hi Anand,
yes, the EC might go down as also indicated in the configuration guide:
"An EtherChannel supports the same allowed range of VLANs on all the ports in a trunking EtherChannel. If the allowed range of VLANs is not the same for a port list, the ports do not form an EtherChannel even when set to the auto or desirable mode with the set port channel command."
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst6500/catos/8.x/configuration/guide/channel.html#wp1026624
consider for the worst case scenario a short manteincance window for the change. If you are fast enough the EC might not 'notice' the change and stay up, but it might go down.
Riccardo
rsimoni
Hi Anand,
Vlan 135 is already in the trunk!
In general the command to add a vlan to an existing trunk is
set trunk 1/2 on dot1q 140
While you add or remove vlans there is no impact for the other vlans carried in the trunk (beside the ones you are removing, obviously)
check also this out
http://topic-rtp.cisco.com/taccc/lanswitching_K11881886.html
Please rate and close the thread if helpful
Riccardo
Ricardo, Thank you for your reply.
  Since i'm changing the config one port at a time (since the port channel includes 2 ports) and this port channel is the only uplink to the distribution.
will it cause any impact/outage or will i loose connectivity since i'm configuring it remotely?
Hi Anand,
Riccardo
