07-28-2007 06:22 AM - edited 03-05-2019 05:32 PM
I have a 4507r and have added a new interface vlan 75 with an ip address of 10.75.0.1. I have created an ospf route for the 10.75.0.0 network in the 0 area but for some reason I cannot ping it.
Here is the config in question...
interface Vlan75
ip address 10.75.0.1 255.255.0.0
no ip redirects
router ospf 2
log-adjacency-changes
redistribute static metric 200 subnets
network 10.50.0.0 0.0.255.255 area 0
network 10.75.0.0 0.0.255.255 area 0
When I do a show ip route 10.50.0.0 I get..
Routing entry for 10.50.0.0/16
Known via "connected", distance 0, metric 0 (connected, via interface)
Routing Descriptor Blocks:
* directly connected, via Vlan23
Route metric is 0, traffic share count is 1
but for 10.75.0.0 I get
% Subnet not in table
Any ideas?
Solved! Go to Solution.
07-29-2007 11:46 AM
What if I were to want to have a vlan on the 4948 that has 12 ports on it, but I don't want traffic to leave that vlan?
07-29-2007 12:03 PM
William,
You can use whatever VLANs you require on the 4948 and by default the traffic don't leave the VLAN unless inter-VLAN routing is configured by using SVI interfaces (interface vlan x and interface vlan y and so on) on a layer 3 switch, and accordingly in the context of a layer 2 switch the VLAN traffic can't be seen by another VLAN.
HTH,
Mohammed Mahmoud.
07-29-2007 12:11 PM
So your saying as long as I only use...
vlan XX
and not use interface vlans then the traffic will stay within that vlan?
07-29-2007 12:27 PM
Yes thats right, by default if the switch is layer 2 switch with just vlan configuration there can be no communication between the vlans, unless the switch is converted to layer 3 functionality (ip routing) and SVI interfaces are configured (interface vlan).
HTH,
Mohammed Mahmoud.
07-29-2007 12:35 PM
I have heard about vlans not being secure... Can you comment on this? something like "vlan snooping????"
