Adjusting queuing on 6509 gig e port
wilson_1234_2
Level 3
Level 3
We have been having some trouble with a disk to disk backup from one device to another.
One of the ports is showing output drops, and I am not sure how to interperate the Queueing output.
GigabitEthernet9/10 is up, line protocol is up
Hardware is C6k 1000Mb 802.3, address is 0002.7e39.8ecd (bia 0002.7e39.8ecd)
Description: 10.1.11.52 test spot
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
input flow-control is off, output flow-control is on
Clock mode is auto
Last input never, output 00:00:18, output hang never
Last clearing of "show interface" counters 1w6d
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 565750
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 1000 bits/sec, 1 packets/sec
3302909568 packets input, 236242332513 bytes, 0 no buffer
Received 21373 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
9575391701 packets output, 14301832898411 bytes, 0 underruns
#sh queueing interface g9/10
Interface GigabitEthernet9/10 queueing strategy: Weighted Round-Robin
Port QoS is enabled
Port is untrusted
Extend trust state: not trusted [COS = 0]
Default COS is 0
Queueing Mode In Tx direction: mode-cos
Transmit queues [type = 1p2q2t]:
Queue Id Scheduling Num of thresholds
1 WRR low 2
2 WRR high 2
3 Priority 1
WRR bandwidth ratios: 100[queue 1] 255[queue 2]
queue-limit ratios: 70[queue 1] 15[queue 2] 15[Pri Queue]*same as Q2
queue random-detect-min-thresholds
1 40[1] 70[2]
2 40[1] 70[2]
queue random-detect-max-thresholds
1 70[1] 100[2]
2 70[1] 100[2]
queue thresh cos-map
1 1 0 1
1 2 2 3
2 1 4 6
2 2 7
3 1 5
Queueing Mode In Rx direction: mode-cos
Receive queues [type = 1p1q4t]:
1 Standard 4
2 Priority 1
queue tail-drop-thresholds
1 100[1] 100[2] 100[3] 100[4]
1 1 0 1 2 3 4 5 6 7
1 2
1 3
1 4
2 1
Packets dropped on Transmit:
BPDU packets: 0
queue thresh dropped [cos-map]
1 1 565750 [0 1 ]
1 2 0 [2 3 ]
2 1 0 [4 6 ]
2 2 0* [7 ]
3 1 0* [5 ]
* - shared transmit counter
Packets dropped on Receive:
BPDU packets: 0
1 1 0 [0 1 2 3 4 5 6 7 ]
* - shared receive counter
Could I adjust the queueing to make this more efficient?
Joseph W. Doherty
"Could I adjust the queueing to make this more efficient?"
Perhaps. Much depends on whether there's insufficient bandwidth, where drops are going to happen, or whether there's insufficient device allocation. For instance, for the latter, increasing the buffer allocation for this traffic might decrease the drops.
Also you need to consider whether the drop rate % is high enough to be an issue (not the absolute number). Assuming your counters haven't wrapped, your drop percentage is only .006%, which often shouldn't be an issue.
We moved the devices to a dell 48 port switch with no qos appled.
Is it possible the qos policy could be affecting the throughput of this data?
The jobs are running at night when the switch has very little else it needs to do.
"Is it possible the qos policy could be affecting the throughput of this data? "
Yes.
(NB: QoS polices can have no effect, negative effect or positive effect. Of course, we attempt for the postive effect.)
pciaccio
Level 4
Level 4
Your issue may not be queue size related. It may be Flow control related. I see that you have Input flow control off. I would set flow control to on for both send and receive for your port. To verify if the port is being over run, use the show interface gig xx/yy flowcontrol command. If you have issues you will see them there. Enable the flowcontrol on both the switch and server or NAS or storage side on the NIC cards. Good Luck...
