IOS installation from xmodem
austin0824
I attempted re-installing the IOS image of my 3750 switch which was formatted in error. When I open hyperterminal, and select default setting (9600 baud etc etc), below is what I get.
Base ethernet MAC Address: 00:12:d9:95:db:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: filesystem check interrupted!
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
The system has been interrupted, or encountered an error
during initializion of the flash filesystem. The following
commands will initialize the flash filesystem, and finish
loading the operating system software:
flash_init
load_helper
boot
switch: flash_init
flashfs[0]: 2 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 2560
flashfs[0]: Bytes available: 15996416
flashfs[0]: flashfs fsck took 7 seconds.
Setting console baud rate to 9600...
switch: load_helper
switch: copy xmodem: flash:c3750-ipservicesk9-mz.122-25.SEE2.bin
Begin the Xmodem or Xmodem-1K transfer now...
CCCCCCCCCCBB0BB0xmodem:: I/O error
switch:
Any ideas on what I am missing out to get this right.
Cheers
John Blakley
If it's not already off, try turning flow control off before connecting to the switch.
HTH,
John
HTH, John *** Please rate all useful posts ***
Tshi M
Level 5
Level 5
take a look at this link: http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
I will also suggest increasing the baude rate to speed up the transfer.
