administrative distance for the ospf routes
ROMAN TOMASEK
is possible to display AD for some ospf routes which are not in the RIB? For example, when I changed AD for one neighbor (10.0.0.1 AD 150) - I can see this information in the show ip protocol. But I can see only the AD for the neighbor. I can't to see AD for each route:-( When I use show ip route - I can see only the best routes and their AD. I can't to see AD for routes which are not in the routing table. Is possible to display it??
Roman
Reza Sharifi
Roman,
Administrative distance is locally significant.  It will not be advertised in routing updates.
Reza
thank you. I know it. It doesn't answer for my question. My question is following. Where can I display AD per network which is not in the routing table? The router received a routing update from its network, it adds AD for all networks in this update and than this router compare AD for same networks and networks with the best AD is added to the routing table. I want to display the AD for the networks which are not in the routing table. Thank you.
Roman
