ADSL on cisco 2600
anupk
I have cisco 2600 router which already has 512 MB leased line connectivity. I would like to add an additional adsl line. can any one suggest me the possibility?
Amit Singh
Anup,
You can use ADSL's WIC on the 2600 router. You have to check the WIC slot avaialbility on your router.
WIC-1ADSL-I-DG 1-Port ADSLoISDN WAN Interface Card
WIC-1ADSL 1-port ADSL WAN Interface Card
WIC-1SHDSL 1-Port G.SHDSL WIC
WIC-1SHDSL-V2 1-Port two or four wire G.SHDSL WIC
WIC-1ADSL-DG 1-Port ADSL WAN Interface Card with Dying gasp
Please see the link below for WIC info
http://www.cisco.com/en/US/products/hw/routers/ps259/products_relevant_interfaces_and_modules.html
-amit singh
Dear Amit
ADSL WIC required IOS higher than v 12. which i cannot upgrade since my router does not have enough memory /flash.
now i am planning to install NM-1E - 1 port ethernet network module and connect ADSL line into it.
Can you tell me whether this card support 2600 router and how adsl can be configured.
Thanks, Anup
