Abnormal Routing.
mansoor_nawaz78
Level 3
Level 3
We are facing a routing problem, that when we trace route to the same Destination, different routes appear every time when we trace the same destination.
and also facing Uploading and MSN messanger loging problem, because of this...
Danilo Dy
I assume the route is through internet since you mention MSN. There could be route flapping (BGP). Check the route, what is the last hop before the route change path everytime you do a traceroute? Contact the ISP of that hop to report the problem.
