Advertising a network - EIGRP - without using the network command
danny9797
Level 4
Level 4
Hi everyone,
In EIGRP, a network/subnet can be advertised with the network command but what other methods or work arounds can be used and configured for a particular network in order to advertise that subnet out to it's neighbours.
Reza Sharifi
You can also use the redistribute command under EIGRP to redistribute from static to EIGRP and/or redistribute directly connected interfaced to EIGRP.
singhaam007
Level 9
Level 9
hello,
use redistribute static for your static routes and you can use distribute list with an access list to redistribute routes but with filtering .
http://www.cisco.com/en/US/docs/ios/12_1/iproute/command/reference/1rdeigrp.html
hope this will help.
thanks
