I am planning to set up EMS/SNMP monitoring using server/pc for my Cisco switch, router and firewall. It will also used as as snmp trap and tftp server for router/switch software upgrade.
Appreciate very much if what is the best option for OS, either WinXp or Linux of the pc/server to accomplish this task.
the server/pc will be on 24/7 and i am looking for simple-to-configure, reliable, friendly way to do this job. Somemore, it should not be easily crashed.
btw: snmp software might be solarwinds, mrtg.
thanks in advance
