after converting 6500 cisco to vss, is there existing config will gooff or still will be available ?
Hi Team,
after converting 6500 cisco switch  to vss, is there existing config will gooff or still will be available with different interface number?
- i need existing configuration should be available after vss any challenges please ?
Reza Sharifi
Once you convert to VSS, the configuration will change, as port numbering for VSS is not the same as individual switches. For example if a port in the individual switch was gi2/1, in VSS it will be 1/2/1 (switch 1) or 2/2/1 (switch 2).
Reza Sharifi
is there other than interface numbering, any other existing config will change ?
