12-22-2012 08:42 AM - edited 03-07-2019 10:44 AM
Hi Everyone,
I was studying about IPSEC VPN here it says that
Once Data transmission is completed and timeout is reached the IPSEC tunnel will be torn down.
Need to know what does this mean?
Does this mean after x amount of data is transferred then the tunnel will be brought to down and it will regoniate the tunnel?
If tunnel is tear down do i see message in log that tunnel is down ?
When we say tunnel is tear down doe sit mean that physical interface is down?
When tunnel is tear down then does site 1 loses connectivity to site 2?
Where we config this timeout option?
Mahesh
Solved! Go to Solution.
12-22-2012 11:15 AM
Hi Mahesh,
Correct. In my case I just have any any in the access-list because this is just a test environment.
Here is the access list increment before and after ping
R2#sh access-lists 101
Extended IP access list 101
10 permit gre any any (9 matches)
R2#ping 20.20.20.20
Sending 5, 100-byte ICMP Echos to 20.20.20.20, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
10 permit gre any any (19 matches)
R2#
Reza
12-22-2012 09:56 AM
Hi Mahesh,
IF the tunnel is not active for a certain amount of time, the router will bring down the tunnel. Once you start sending packets again, it will bring it back up. Have a look at this example. At first the tunnel is down, once I start pinging the other router, the session comes back up:
R2#sh crypto session
Crypto session current status
Interface: GigabitEthernet0/0
Session status: DOWN
Peer: 1.1.1.2 port 500
IPSEC FLOW: permit 47 0.0.0.0/0.0.0.0 0.0.0.0/0.0.0.0
Active SAs: 0, origin: crypto map
R2#ping 20.20.20.20
Success rate is 80 percent (4/5), round-trip min/avg/max = 1/2/4 ms
Session status: UP-ACTIVE
IKE SA: local 10.1.1.1/500 remote 1.1.1.2/500 Active
Active SAs: 2, origin: crypto map
Reza
12-22-2012 11:07 AM
Hi Reza,
By traffic here you mean interesting traffic that is described by ACL right?
MAhesh
12-22-2012 11:15 AM
Hi Mahesh,
R2#ping 20.20.20.20
R2#
Reza
12-22-2012 11:45 AM
Hi Reza,
Many thanks for help.
MAhesh
