IPSEC tunnel and Routing protocols
mahesh18
Level 6
Level 6
Hi Everyone,
I read IPSEC does not support Routing Protocols with Site to Site VPN as they both are Layer4.
Does it mean that If Site A  has to reach Site B over WAN  link we should use Static IP on Site A and Site B  Router?
In my home Lab i config Site to Site IPSES  VPN  and they are working fine using OSPF  does this mean that IPSEC supports Routing Protocol?
IF someone can explain me this please?
Mahesh
7 Replies 7
cadet alain
to use a routing protocol using multicast with a IPSec VPN tunnel you need ;
- use IPSec over GRE as GRE supports multicast
- configure a VTI IPSec tunnel compared to a crypto-map IPSec tunnel.
Regards.
Alain
Hi Alain,
Can  you please explain me what is VTI IPSEC tunnel?
Mahesh
traditional IPSec VPN tunnel is using crypto map assigned to outbound interface and this crypto map is matching a crypto ACL which means that you have to initiate interesting traffic( traffic permitted in this crypto ACL to initiate the tunnel.
A VTI tunnel is not using crypto map but instead a tunnel interface is created and all traffic routed through this tunnle will be encrypted by IPSec.
http://www.ccierants.com/2009/09/ipsec-with-vti-best-damn-way-to-do-it.html
Regards.
Alain
Abzal
Level 7
Level 7
If you configure OSPF neighbor and point a static route to subnets behind IPSEC router it is possible. IPSEC as far I know supports only unicast packets over VPN tunnel. For example GRE supports both multicast and unicast that's why it supports OSPF, EIGRP like dynamic protocols.
Can you post config of ospf and tunnel interface as well ip routes.
Best regards,
Abzal
Hi Abzal,
I am not using GRE
Side B
router ospf 1
router-id 3.4.4.4
log-adjacency-changes
area 10 virtual-link 10.4.4.1
passive-interface Vlan10
passive-interface Vlan20
network 3.4.4.4 0.0.0.0 area 0
network 192.168.4.0 0.0.0.255 area 10
network 192.168.5.0 0.0.0.255 area 0
network 192.168.10.0 0.0.0.255 area 0
network 192.168.20.0 0.0.0.255 area 0
network 192.168.30.0 0.0.0.255 area 0
network 192.168.98.0 0.0.0.255 area 0
network 192.168.99.0 0.0.0.255 area 0
3550SMIA#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.5.3 to network 0.0.0.0
O    192.168.12.0/24 [110/13] via 192.168.5.3, 3d17h, FastEthernet0/11
     100.0.0.0/32 is subnetted, 1 subnets
O       100.100.100.100 [110/3] via 192.168.5.3, 3d17h, FastEthernet0/11
     3.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
O       3.3.3.3/32 [110/2] via 192.168.5.3, 3d17h, FastEthernet0/11
C       3.4.4.0/24 is directly connected, Loopback0
C    192.168.30.0/24 is directly connected, Vlan30
     64.0.0.0/32 is subnetted, 1 subnets
O E2    64.59.135.150 [110/300] via 192.168.5.3, 1d09h, FastEthernet0/11
O       4.4.4.4 [110/2] via 192.168.5.3, 3d17h, FastEthernet0/11
C    192.168.10.0/24 is directly connected, Vlan10
     172.31.0.0/24 is subnetted, 4 subnets
O E2    172.31.3.0 [110/300] via 192.168.5.3, 3d17h, FastEthernet0/11
O E2    172.31.2.0 [110/300] via 192.168.5.3, 3d17h, FastEthernet0/11
O E2    172.31.1.0 [110/300] via 192.168.5.3, 3d17h, FastEthernet0/11
O E2    172.31.0.0 [110/300] via 192.168.5.3, 3d17h, FastEthernet0/11
O    192.168.11.0/24 [110/3] via 192.168.5.3, 3d17h, FastEthernet0/11
O    192.168.98.0/24 [110/2] via 192.168.99.1, 3d17h, FastEthernet0/8
C    192.168.99.0/24 is directly connected, FastEthernet0/8
C    192.168.20.0/24 is directly connected, Vlan20
     192.168.5.0/31 is subnetted, 1 subnets
C       192.168.5.2 is directly connected, FastEthernet0/11
C    10.0.0.0/8 is directly connected, Tunnel0
     192.168.6.0/31 is subnetted, 1 subnets
O       192.168.6.2 [110/2] via 192.168.5.3, 3d17h, FastEthernet0/11
O    192.168.1.0/24 [110/13] via 192.168.5.3, 3d17h, FastEthernet0/11
O*E2 0.0.0.0/0 [110/1] via 192.168.5.3, 1d09h, FastEthernet0/11
Side A
router ospf 1
network 192.168.97.0 0.0.0.255 area 0
1811w#  sh ip route
Gateway of last resort is 192.168.99.2 to network 0.0.0.0
O    192.168.12.0/24 [110/14] via 192.168.99.2, 3d17h, FastEthernet0
O       100.100.100.100 [110/4] via 192.168.99.2, 3d17h, FastEthernet0
     3.0.0.0/32 is subnetted, 2 subnets
O       3.3.3.3 [110/3] via 192.168.99.2, 3d17h, FastEthernet0
O       3.4.4.4 [110/2] via 192.168.99.2, 3d17h, FastEthernet0
O    192.168.30.0/24 [110/2] via 192.168.99.2, 3d17h, FastEthernet0
O E2    64.59.135.150 [110/300] via 192.168.99.2, 1d09h, FastEthernet0
O       4.4.4.4 [110/3] via 192.168.99.2, 3d17h, FastEthernet0
O    192.168.10.0/24 [110/2] via 192.168.99.2, 3d17h, FastEthernet0
O E2    172.31.3.0 [110/300] via 192.168.99.2, 3d17h, FastEthernet0
O E2    172.31.2.0 [110/300] via 192.168.99.2, 3d17h, FastEthernet0
O E2    172.31.1.0 [110/300] via 192.168.99.2, 3d17h, FastEthernet0
O E2    172.31.0.0 [110/300] via 192.168.99.2, 3d17h, FastEthernet0
O    192.168.11.0/24 [110/4] via 192.168.99.2, 3d17h, FastEthernet0
C    192.168.98.0/24 is directly connected, BVI98
O    192.168.20.0/24 [110/2] via 192.168.99.2, 3d17h, FastEthernet0
O       192.168.5.2 [110/2] via 192.168.99.2, 3d17h, FastEthernet0
O       192.168.6.2 [110/3] via 192.168.99.2, 3d17h, FastEthernet0
O    192.168.1.0/24 [110/14] via 192.168.99.2, 3d17h, FastEthernet0
O*E2 0.0.0.0/0 [110/1] via 192.168.99.2, 1d09h, FastEthernet0
This shows that both sides are communicating via OSPF  right ?
Mahesh
this doesn't show they are using the IPSec tunnel to do it .
Regards.
Alain
But does this show
3550SMIA#sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id slot status
192.168.99.2    192.168.99.1    QM_IDLE           1005 ACTIVE
3550SMIA#sh crypto ipsec sa
interface: FastEthernet0/8
    Crypto map tag: VPN_MAP, local addr 192.168.99.2
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (192.168.99.0/255.255.255.0/0/0)
   remote ident (addr/mask/prot/port): (192.168.0.0/255.255.0.0/0/0)
   current_peer 192.168.99.1 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 4114, #pkts encrypt: 4114, #pkts digest: 4114
    #pkts decaps: 4055, #pkts decrypt: 4055, #pkts verify: 4055
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 2, #recv errors 0
     local crypto endpt.: 192.168.99.2, remote crypto endpt.: 192.168.99.1
     path mtu 1500, ip mtu 1500
     current outbound spi: 0xC936CF9D(3375812509)
     inbound esp sas:
      spi: 0xB481DC3B(3028409403)
        transform: esp-des esp-sha-hmac ,
        in use settings ={Tunnel, }
        conn id: 189, flow_id: 189, crypto map: VPN_MAP
        sa timing: remaining key lifetime (k/sec): (4519331/2630)
        IV size: 8 bytes
        replay detection support: Y
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 190, flow_id: 190, crypto map: VPN_MAP
        sa timing: remaining key lifetime (k/sec): (4519338/2626)
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
3550SMIA#
1811w#sh crypto isakmp sa
dst             src             state          conn-id status
192.168.99.2    192.168.99.1    QM_IDLE           2005 ACTIVE
IPv6 Crypto ISAKMP SA
So this shows that they are using IPSEC  tunnel right?
Mahesh
