After upgradeing the Cisco Nexus 5596T from 7.0.7.N1.1.bin to 7.3.1.N1.1.bin
mmatti
I followed the right path from  7.0.7.N1.1.bin 7.1.4.N1.1.bin 7.3.1.N1.1.bin and the switches are up and running. The problem is after the upgrade I see input discards on may interfaces and I know where those are coming form. It is the backup server but I didn't have this issue before the upgrade. so what is the difference? Is that a bug in the IOS or the former IOS was not reporting correctly?
Mike Matti
DFCU Financial
Reza Sharifi
Looking at the release notes, I don't see anything about discards after the upgrade, but that does not mean there is no bug in the new image specially since this started after the upgrade.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5500/sw/release/notes/7x/Nexus5500_Release_Notes_7x.html
Reza Sharifi
Thanks for your reply. I may try to downgrade and wait till cisco comes with new IOS
Glad to help. You may also want to open a ticket with TAC and send them the outputs with discards frames.
