Aggregating Two VLAN Trunks
daredavel
I'm kinda new in VLAN and setup my own lab via packet tracer. I'm trying to aggregate the two trunk connection that I setup but can't seem to make it work. What am I possible missing? How can I do it correctly?
Julio E. Moisa
If you want to make an etherchannel you need first make they have the same interface capabilities, all of them need to be FastEthernet or GigaEthernet, same speed, duplex.
So on your example I recommend FastEthernet only or GigaEthernet only.
Now once they are equal interface, you can use, example:
interface range g0/1-2   <--- range of ports
channel-group 10 mode active  <---   (LaCP on both switches)
switchport mode trunk
no shut
interface port-channel 10
switchport trunk encapsulation dot1q  (if it is not implicit)
no shutdown
it could be useful:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_55_se/configuration/guide/3750xscg/swethchl.html
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
no shut
no shutdown
it could be useful:
Thank you for responding julio! Should I just change the mode of fa0/24 to access mode and it will be remove as trunk and encapsulated? Thank you again.
Hi Dave
Please correct me if I understand the question wrongly. If mode access is configured under the interface it will not overwrite the trunk mode, it will have both mode under the interface and it is not considered as a good practice, it should be access or trunk but it cannot be both.
