air 1240 AG
Mohammed Yusuf
By mistake I deleted boot file and now access point only boots up in ap mode.
When I run Dir I get nothing.
How can I restore the image back?
I have tried Hyper terminal modem but it failed.
So here is the steps
1. Download this image c1240-k9w7-tar.124-25d.JA2.tar
2. Rename it as c1240-k9w7-tar.default
3. Connect your PC acting as TFTP server directly to your AP ethernet & assign PC 10.0.0.2/8 (gateway 10.0.0.1) IP.
4. While press the mode button power on the AP (using external power adapter).
5 Hold the mode button for 20-30s & then release it.
6. If you monitor the console output you should see the AP will download the image from your TFTP server onto it.
Refer this for more detail
http://mrncciew.com/2013/12/13/ap-conversion-using-mode-button/
Rasika
**** Pls rate all useful responses ***
This should help you on this
https://supportforums.cisco.com/thread/2045805
Rasika
**** Pls rate all useful responses ****
I am struggling to assign IP address as I only get
ap:
ap:
I can only use dir command.
Rasika
