Allow Multicast IP packets through router
mustafa.chelik
I have very simple network: PC-1 -> Cisco 2900 Series Router <- PC-2
PC-1 streams a video with 234.5.5.5:4000 IP/Port and PC-2 should receive and render it. But by default the router doesn't route multicast packets to other side. I found some information for this like ip multicast-routing, but it didn't work. Can someone tell me exact commands to enable multicasting in Cisco 2900 Series Router?
Thank you
From the mroute output -
(10.0.0.7, 234.5.5.5), 00:09:03/00:01:49, flags: PLT
  Incoming interface: GigabitEthernet0/0, RPF nbr 0.0.0.0
  Outgoing interface list: Null
your client that is meant to receive the stream is not sending an IGMP join request to the router.
What software are you using on the client PC ?
Jon
20 Replies 20
Jon Marshall
If the network really does consist of just the router then you can run PIM dense mode so -
1) enable multicast routing ie. "ip multicast-routing"
2) under each interface on the router connecting to the PCs enable PIM ie.
int <x/y>
ip pim dense-mode
3) make sure the multicast stream has a TTL > 1 which is not something you do on the router, it is configured within the multicast software on the sending device.
Jon
Thank you Jon; for your reply. I entered these commands:
  • conf t
  • ip multicast-routing
  • int gi0/0
  • ip pim dense-mode
  • exit
  • int gi0/1
  • ip pim dense-mode
  • end
But unfortunately my 234.5.5.5 UDP packets with TTL=64 could not pass through the router. I deleted every ACL and disabled every ip inspect. What do you suggest?
BTW, can I allow only specific multicast packets?
Thank you
What software are you using to generate the multicast stream ?
You can limit which multicast streams are allowed with an acl.
Jon
I used three:
  1. VLC with TTL=64 parameter
  2. My custom DirectShow video streamer with TTL=64
  3. A device that stream PAL camera with TTL=60
At every application I opened WireShark and verified TTL value in UDP packets.
I would be happy if you tell me how to set ACL for multicast routing (I'm newbie).
Thank you very much
Basically the acl is just a normal acl using multicast IPs, nothing special.
If you have confirmed the TTL I> 1 then it should have worked.
Can you post the router configuration.
Jon
Actually I deleted every settings I applied before. At this moment I don't have any specific setting. I just set IP address of router interfaces (10.0.0.50 and 20.0.0.50). If you ask about any specific setting, please tell me so I post it to you.
Thank you very much Jon
I set my router to it's factory settings using write erase and reload commands. After factory reset, I only changed IP address of interfaces and then input the commands you told me. It did not work again.
Can you post the configuration.
Jon
I run show running-config command and since the result was too long, I uploaded it's file. Sorry about it.
By the way my interfaces' IP addresses are:
Gi0/0: 10.0.0.50 255.255.255.0
Gi0/1: 20.0.0.50 255.255.255.0
Can the PCs ping each other ?
Jon
Yes, and they can open each other's shared folders.
Okay, then you should not need any more configuration than I posted.
Can you add back the multicast configuration and then test again and post the following outputs from the router -
1) "sh ip igmp membership"
2) "sh ip mroute"
Jon
I set again ip multicast-routing and ip pim dense-mode commands and it did not work. So I entered the commands you requested. I attached the result. By the way, as you can see I entered sh ip igmp membership command, and then entered ip igmp membership 234.5.5.5 command and then again entered sh ip igmp membership command again.
I hope you will understand the problem.
Thank you very much for your time sir
Jon
