Allowing RDP Access Through 1711 using PPPoE
niall-wilkins
Hey All,
I am trying allow Remote Desktop Access through my 1711 router thats using PPPOE. I have configured the following line in my config
ip nat source static udp 10.1.20.2 3389 interface dialer 1 3389
but I cant RDP to the computer on my network with the IP of 10.1.20.2. I need to make this computer accessible from the internet via RDP but at the same time allow other computers access to the internet. Here is a copy of my config as well. Is it because I am missing an access-list??
Current configuration : 1790 bytes
version 12.4
service password-encryption
hostname Cisco_1711
boot-start-marker
boot-end-marker
enable password 7 052D1400265F1B5F4E5D
no aaa new-model
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip dhcp use vrf connected
ip dhcp pool Data_Vlan_20
network 10.1.20.0 255.255.255.0
default-router 10.1.20.1
ip domain name home.com
username xxxxxxxxx password 7 xxxxxxxxxx
interface FastEthernet0
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface FastEthernet1
interface FastEthernet2
switchport access vlan 30
interface FastEthernet3
interface FastEthernet4
switchport access vlan 20
interface Vlan1
no ip address
interface Vlan20
ip address 10.1.20.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1380
interface Vlan30
ip address 192.168.150.1 255.255.255.0
ip nat inside
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp pap sent-username xxxxxxx password 7 xxxxxxxx
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat source static udp 10.1.20.2 3389 interface Dialer1 3389
ip nat inside source list NAT_ADDRESSES interface Dialer1 overload
ip access-list extended NAT_ADDRESSES
permit ip host 10.1.20.2 any
permit ip host 192.168.150.2 any
permit ip host 10.1.20.3 any
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input ssh
end
Sannie179
Greetings,
RDP uses tcp to establish the connection on port 3389, try changing your static nat statement to this:
ip nat source static tcp 10.1.20.2 3389 interface Dialer1 3389
Sannie
Sannie179
Greetings,
Sannie
I added
but I still can not RDP to this computer over the internet. RDP works on the internal network so I know its not a windows issue. Is their a debug command I can run to see whats happening?
1-can you add the keyword: extendable at the end of the rdp nat and try again?
2-r you making rdp to the public IP or the private ip?
3-is there any firewall between rtr and PC?
I resolved the issue by excluding the IP address 10.1.20.2 from DHCP. It wasnt working because the PC was getting a dynamic IP. Anyway thanks for the help
