09-15-2008 10:47 AM - edited 03-06-2019 01:23 AM
hi every body!
I just want to know if alternate port on a switch misses tree bpdu, will the switch put the alternate port immediately in forwarding state?
thanks a lot!
Solved! Go to Solution.
09-15-2008 10:56 AM
Hi Sarah,
RSTP or MST will change the role to designated, but the state would still be discarding in that case. You would need to miss BPDUs for 30 additional seconds in order to go forwarding.
F.
09-15-2008 10:56 AM
Hi Sarah,
F.
