Alternate to IP SLA
CCDECCDE9
I have 1811 router.It has FastEthernet and Dial up Interface.I want to use this router to connect to Internet via FastEthernet as Primary Connection and if this fails I want to connect to INternet via Dialup Interface.Is there a way to achieve this configuration other than IP SLA ?
7 Replies 7
Lucien Avramov
Level 10
Level 10
Are you doing that over ISDN or T1?
If you have dialer interface, you can use the backup keyword for this.
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_configuration_example09186a008010456b.shtml
I am using DSL high speed connection
Any ideas ?
I am using DSL high Speed Connection as primary
It would be ip sla with a tracking object or EEM with tracking the sla operation
I know how IP SLA works but EEM ?can you please elaborate or provide link
I would say the easiest is to use object tracking with IPSLA.
EEM would involve a more complex configuration.
Check this post which provides an example of IP SLA with EEM:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Network%20Management&topicID=.ee71a02&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cd4b0c6/20#selected_message
