And Yet Another PoE Problem
Ivan Villagomez
hi Guys
I just received 12 Cisco IP Cameras  2600 i was configuring them on the same port of my switch 3750-X and out of the 12 Cameras, 5 are sending me the next debug:
*Mar  1 00:15:58.809: ILP uses DC Disconnect(Gi1/0/9): state= ILP_BAD_POWER_S, event= BAD_PWR_TIMER_EV
*Mar  1 00:15:58.809: ILP Power apply to ( Gi1/0/9 ) Okay
*Mar  1 00:15:58.809: ILP Power Accounting RELEASE_PWR ( Gi1/0/9 ) Okay, pwr_used= 0
*Mar  1 00:15:58.809: ILP Start Power Controller phone detection ( Gi1/0/9 ) Okay
*Mar  1 00:15:58.809: ILP Start PHY Cisco IP phone detection ( Gi1/0/9 ) Okay
*Mar  1 00:15:59.447: ILP State_Machine ( Gi1/0/9 ): State= ILP_DETECTING_S, Event= IEEE_CLASS_DONE_EV
*Mar  1 00:15:59.447: **** Instance 0 : Sub Address 0 *****
*Mar  1 00:15:59.447: ***************************************
*Mar  1 00:15:59.447: ILP uses DC Disconnect(Gi1/0/9): state= ILP_DETECTING_S, event= IEEE_CLASS_DONE_EV
*Mar  1 00:15:59.447: %ILPOWER-7-DETECT: Interface Gi1/0/9: Power Device detected: IEEE PD
*Mar  1 00:15:59.447: ILP Power apply to ( Gi1/0/9 ) Okay
*Mar  1 00:15:59.447: ILP Power Accounting REQ_PWR ( Gi1/0/9 ) Okay sys_used=15400
*Mar  1 00:15:59.790: ILP State_Machine ( Gi1/0/9 ): State= ILP_PD_DETECTED_S, Event= IEEE_TSTART_FAULT_EV
*Mar  1 00:15:59.790: **** Instance 0 : Sub Address 0 *****
*Mar  1 00:15:59.790: ***************************************
*Mar  1 00:15:59.790: ILP uses DC Disconnect(Gi1/0/9): state= ILP_PD_DETECTED_S, event= IEEE_TSTART_FAULT_EV
*Mar  1 00:15:59.790: ILP Power apply to ( Gi1/0/9 ) Okay
*Mar  1 00:15:59.790: ILP Power Accounting RELEASE_PWR ( Gi1/0/9 ) Okay, pwr_used= 0
*Mar  1 00:15:59.790: ILP Power problem detected ( Gi1/0/9 )
*Mar  1 00:15:59.790: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/9: Power Controller reports power Tstart error detected
*Mar  1 00:15:59.790: ILP State_Machine ( Gi1/0/9 ): State= ILP_BAD_POWER_S, Event= ILP_POWER_POLICE_DISABLE_EV
*Mar  1 00:15:59.790: ILP uses DC Disconnect(Gi1/0/9): state= ILP_BAD_POWER_S, event= ILP_POWER_POLICE_DISABLE_EV
*Mar  1 00:16:08.791: ILP State_Machine ( Gi1/0/9 ): State= ILP_BAD_POWER_S, Event= BAD_PWR_TIMER_EV
*Mar  1 00:16:08.791: **** Instance 0 : Sub Address 0 *****
*Mar  1 00:16:08.791: ***************************************
Ive tried rebooting the switch, upgradin the IOS to latest version, etc.
I know the problem is not the port as i connect another camera and it works.
Do you have any suggestions?
6 Replies 6
Leo Laohoo
Hmmmm ... I've seen this error message a few days ago.
Can you try something for me?
1.  Command:  test cable tdr int Gi1/0/9;
2.  Wait for about 5 to 7 seconds;
3.  Command:  sh cable tdr int Gi1/0/9; and
4.  Please post the complete output.
Interface Speed Local pair Pair length        Remote pair Pair status
Gi1/0/9   auto  Pair A     N/A                N/A         Normal
                Pair B     N/A                N/A         Normal
                Pair C     2    +/- 10 meters N/A         Short
                Pair D     3    +/- 10 meters N/A         Short
This ouput is with the camera connected.
I believe you just solved the issue.
Look at Pair C and Pair D.
Pair C controls PoE and Pair D controls GigabitEthernet.  The result is coming up as "Short".  Ideal result should be "Normal".
The distance of 2 and 3 metres respectively tells me that the cable directly connected to the switch could be faulty and needs to be replaced.
Can you investigate this?
kapathak
A defect has been filed under
CSCtr74459
Symptom:
When we connect CIVS-IPC-2600 cameras to WS-C3750X-24P.  Switch generate
following message and POE doesn't up:
%ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/1:
Conditions:
CIVS-IPC-2600 cameras connected to WS-C3750X-24P.
Workaround:
none
This is still under investigation. You can subscribe to the RSS feed in bug toolkit to get a notification when the bug gets fixed.
Cheers!
Kapil
thx Kapil, i will keep track of the bug.
No worries!
P.S Please mark thread as resolved if this has answered your query!
