another acl in/out question
dannan lin
hi:
i have a router on a stick setup.
there are three vlans
(vlan 10, net:10.10.10.0
vlan 20, net 20.20.20.0
vlan 30,net 30.30.30.0 )
i want to keep each vlan separated  to each other.
so the acl command i used in router are:
access-list 1 deny 20.20.20.0 0.0.0.255
access-list 1 deny 30.30.30.0 0.0.0.255
access-list 1 permit any
access-list 2 deny 30.30.30.0 0.0.0.255
access-list 2 deny 10.10.10.0 0.0.0.255
access-list 2 permit any
access-list 3 deny 10.10.10.0 0.0.0.255
access-list 3 deny 20.20.20.0 0.0.0.255
access-list 3 permit any
my tried to apply "in"for the acl direction
i.e.
interface FastEthernet0/0.3
encapsulation dot1Q 30
ip address 30.30.30.30 255.255.255.0
ip access-group 3 in
i applied three "in"  for each interface. but each vlan can still ping each other.
and then i changed direction to "out" ,surprising it worked.
My question is why "in"direction did not work.  i thought i could block all traffic coming into the router. i.e.
on vlan 10
i reject all traffic with source network 20.20.20.0 and 30.30.30.0 comming to the interface f0/0.1
it make sense doesn't it ?  but why it dosn't work? why i must use "out" here?
thanks in advance.
below is complete config
ip dhcp pool v10
network 10.10.10.0 255.255.255.0
default-router 10.10.10.10
ip dhcp pool v20
network 20.20.20.0 255.255.255.0
default-router 20.20.20.20
ip dhcp pool v30
network 30.30.30.0 255.255.255.0
default-router 30.30.30.30
interface Loopback99
ip address 170.1.1.1 255.255.0.0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 10
ip address 10.10.10.10 255.255.255.0
ip access-group 1 out
interface FastEthernet0/0.2
encapsulation dot1Q 20
ip address 20.20.20.20 255.255.255.0
ip access-group 2 out
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line vty 0 4
login
end
Giuseppe Larosa
Hello Dannan,
you are using standard access-lists that look for the IP source address of packets only regardless of direction of application.
the way you write the ACLs make them working like you want only when applied outbound.
in addition to this you have to take in account that packets that are locally generated on the router are not dropped by outbound ACLs.
if you use an extended ACL like
access-list 101 deny ip any 20.20.20.0 0.0.0.255
access-list 101 deny ip any 30.30.30.0 0.0.0.255
access-list 101 permit ip any any
this can be applied inbound on the first subinterface
notice that an extended ACL like the one above matches on source and destination addresses and so the IP subnets of the other two subinterfaces have been moved to the destination part
Hope to help
Giuseppe
hello Giuseppe:
thanks for your help .
Reza Sharifi
Basically, it is the other way around.
if you apply an access list inbound, it filters traffic coming from end devices in that vlan
if you apply an access list outbound, it filters traffic going to end devices in that vlan
Define In, Out, Inbound, Outbound, Source, and Destination
The router uses the terms in, out, source, and destination as       references. Traffic on the router can be compared to traffic on the highway. If       you were a law enforcement officer in Pennsylvania and wanted to stop a truck       going from Maryland to New York, the source of the truck is Maryland and the       destination of the truck is New York. The roadblock could be applied at the       Pennsylvania–New York border (out) or the Maryland–Pennsylvania border (in).
When you refer to a router, these terms have these meanings.
  • Out—Traffic that has already been through the router           and leaves the interface. The source is where it has been, on the other side of           the router, and the destination is where it goes.
  • In—Traffic that arrives on the interface and then           goes through the router. The source is where it has been and the destination is           where it goes, on the other side of the router.
  • Inbound —If the access list is inbound, when the           router receives a packet, the Cisco IOS software checks the criteria statements           of the access list for a match. If the packet is permitted, the software           continues to process the packet. If the packet is denied, the software discards           the packet.
  • Outbound—If the access list is outbound, after the           software receives and routes a packet to the outbound interface, the software           checks the criteria statements of the access list for a match. If the packet is           permitted, the software transmits the packet. If the packet is denied, the           software discards the packet.
The in ACL has a source on a segment of the interface to which it is       applied and a destination off of any other interface. The out ACL has a source       on a segment of any interface other than the interface to which it is applied       and a destination off of the interface to which it is applied.
Here is the doc:
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml#sourcedefine
Hello Reza,
original poster was using standard ACLs, however you have provided plenty of useful information and links
Best Regards
Giuseppe
