Ansible and OSPF
Joshuabowers
I'm trying to configure Ansible to configure OSPF on a lab router.
So far I can get Ansible to create a Loopback0, but keeps failing on the ospf config.
I'm new to this, so I'm not sure if I'm using the correct model for a cisco 3800 router.
I think you have to use the syntax below ('parents'):
- name: IOS | Configure OSPF
ios_config:
provider: "{{ provider }}"
lines:
- network 10.55.55.0 0.0.0.255 area 0
parents: ['router ospf 1']
6 Replies 6
ios_config:
lines:
Can you explain the Parents syntax, just I can understand when to use it?
the 'parent' syntax simply means that there is a hierarchy in the commands. In this case, 'router ospf 1' goes first, the networks are then added. In IOS it is:
R3(config)#router ospf 1 <-- Parent Leve;
R3(config-router)#network 10.55.55.0 0.0.0.255 area 0 <--Sub Level
Should I do the same for the interfaces. My loopback code does not have that but works.
Interfaces don't need the parent.
Have you tried the OSPF with the 'parent' ? Does it work ?
Yes it did work. I just had that one question before I select your answer.
