Ansible Ping
Jeric
Frequent Visitor
Frequent Visitor
Is it necessary to distribute the public key to the router/switch in order to use the ansible ping?
I can ssh to the switches using normal ssh but when i use ansible this is the error
ansible all -i inventory -m ping
10.92.38.31 | UNREACHABLE! => {
"changed": false,
"msg": "Failed to connect to the host via ssh: ssh: connect to host 10.92.38.31 port 22: Connection timed out",
"unreachable": true
10.92.38.32 | UNREACHABLE! => {
"changed": false,
"msg": "Failed to connect to the host via ssh: ssh: connect to host 10.92.38.32 port 22: Connection timed out",
"unreachable": true
192.168.211.1 | UNREACHABLE! => {
"changed": false,
"msg": "Failed to connect to the host via ssh: ssh: connect to host 192.168.211.1 port 22: Connection timed out",
"unreachable": true
M02@rt37
Hello @Jeric
Yes, in order to use Ansible with network devices such as routers and switches, it is necessary to distribute the public key to the device. This is because Ansible uses SSH as the transport protocol to communicate with network devices, and SSH uses public key authentication to establish a secure connection between the Ansible control node and the device.
Best regards
