any difference between these PSU's
robertkwild
hi all,
got couple of FEX's but one has a different PSU than the rest, one has the below
PID - N2200-PAC-400W V03
MODEL NO - PS-2421-1-LF REV:08
and the others are these PSU's
PID - N2200-PAC-400W V04
TYPE - EDPS-400AB A REV
does it matter what one i get or as long as i get 2 for the same switch it doesnt matter?
thanks,
rob
Reza Sharifi
Should be fine. V03 vs V04 is just a hardware revision. So, it should not matter as long as the rest of the part number is the same.
