Any problem with this 7609 bootup log?
neutrino0717
I don' have any idea what the following means
*Apr 27 14:52:21.991 GMT: SP: PREDNLD: LC doesn't meet resource requirement for pre-download, not reserving memory for slot 2
I haven't find any useful information on google
any guy help me?
*Apr 27 06:49:45.775: RP: Currently running ROMMON from S (Gold) region
*Apr 27 06:49:54.503: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
000003: *Apr 27 14:49:58.363 GMT: %SYS-6-CLOCKUPDATE: System clock has been updated from 06:49:58 UTC Wed Apr 27 2011 to 14:49:58 GMT Wed Apr 27 2011, configured from console by console.
000004: *Apr 27 14:49:59.395 GMT: %SYS-5-CONFIG_I: Configured from memory by console
000005: *Apr 27 14:50:01.075 GMT: %SYS-5-RESTART: System restarted --
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-IPSERVICES-M), Version 12.2(33)SRD6, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sun 19-Dec-10 13:17 by prod_rel_team
000006: *Apr 27 06:49:15.867: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Firmware compiled 02-Aug-10 16:16 by integ Build [100]
000007: *Apr 27 06:49:53.839: %SPANTREE-SP-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Apr 27 06:49:54.047: SP: SP: Currently running ROMMON from S (Gold) region
000008: *Apr 27 06:49:56.811: %C7600_PLATFORM-SP-4-CONFREG_BREAK_ENABLED: The default factory setting for config register is 0x2102.It is advisable to retain 1 in 0x2102 as it prevents returning to ROMMON when break is issued.
000009: *Apr 27 06:50:00.881: %SYS-SP-5-RESTART: System restarted --
Cisco IOS Software, c7600rsp72043_sp Software (c7600rsp72043_sp-IPSERVICES-M), Version 12.2(33)SRD6, RELEASE SOFTWARE (fc3)
Compiled Sun 19-Dec-10 13:23 by prod_rel_team
000010: *Apr 27 06:50:00.885: %SYS-SP-6-BOOTTIME: Time taken to reboot after reload =  119 seconds
000011: *Apr 27 06:50:03.026 UTC: %OIR-SP-6-INSPS: Power supply inserted in slot 1
000012: *Apr 27 06:50:03.026 UTC: %C7600_PWR-SP-4-PSOK: power supply 1 turned on.
000013: *Apr 27 06:50:03.086 UTC: %OIR-SP-6-INSPS: Power supply inserted in slot 2
000014: *Apr 27 06:50:03.086 UTC: %C7600_PWR-SP-4-PSOK: power supply 2 turned on.
000015: *Apr 27 06:50:03.090 UTC: %C7600_PWR-SP-4-PSREDUNDANTBOTHSUPPLY: in power-redundancy mode, system is operating on both power supplies.
000016: *Apr 27 14:50:09.430 GMT: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 5.
000017: *Apr 27 14:50:09.514 GMT: %FABRIC-SP-5-FABRIC_MODULE_ACTIVE: The Switch Fabric Module in slot 5 became active.
000018: *Apr 27 14:50:10.667 GMT: %DIAG-SP-6-RUN_MINIMUM: Module 5: Running Minimal Diagnostics...
000019: *Apr 27 14:50:14.831 GMT: %DIAG-SP-6-DIAG_OK: Module 5: Passed Online Diagnostics
000020: *Apr 27 14:50:15.215 GMT: %OIR-SP-6-INSCARD: Card inserted in slot 5, interfaces are now online
000021: *Apr 27 14:50:16.303 GMT: %PFREDUN-SP-6-ACTIVE: Standby initializing for SSO mode
000022: *Apr 27 14:50:46.231 GMT: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 6.
000023: *Apr 27 14:50:46.315 GMT: %FABRIC-SP-5-FABRIC_MODULE_BACKUP: The Switch Fabric Module in slot 6 became standby
000024: *Apr 27 14:50:47.063 GMT: %DIAG-SP-6-RUN_MINIMUM: Module 6: Running Minimal Diagnostics...
000025: *Apr 27 14:50:48.311 GMT: %DIAG-SP-6-DIAG_OK: Module 6: Passed Online Diagnostics
000026: *Apr 27 14:50:49.103 GMT: %OIR-SP-6-INSCARD: Card inserted in slot 6, interfaces are now online
*Apr 27 06:50:58.527: CFC2: Currently running ROMMON from S (Gold) region
*Nov 30 00:00:02.659: CFC1: Currently running ROMMON from S (Gold) region
000027: *Apr 27 14:51:00.887 GMT: %DIAG-SP-6-RUN_MINIMUM: Module 1: Running Minimal Diagnostics...
000028: *Apr 27 14:51:00.923 GMT: %DIAG-SP-6-RUN_MINIMUM: Module 2: Running Minimal Diagnostics...
000029: *Apr 27 14:51:04.527 GMT: %DIAG-SP-6-RUN_MINIMUM: Module 3: Running Minimal Diagnostics...
000030: *Apr 27 14:51:04.579 GMT: %DIAG-SP-6-RUN_MINIMUM: Module 4: Running Minimal Diagnostics...
000031: *Apr 27 14:51:08.331 GMT: %DIAG-SP-6-RUN_MINIMUM: Module 9: Running Minimal Diagnostics...
000032: *Apr 27 14:51:10.839 GMT: %DIAG-SP-6-DIAG_OK: Module 1: Passed Online Diagnostics
*Apr 27 14:51:11.067 GMT: SP: PREDNLD: LC doesn't meet resource requirement for pre-download, not reserving memory for slot 1
000033: *Apr 27 14:51:13.395 GMT: %OIR-SP-6-INSCARD: Card inserted in slot 1, interfaces are now online
000034: *Apr 27 06:50:07.803: %SYS-SP-STDBY-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
000035: *Apr 27 06:50:19.931: %C7600_PLATFORM-SP-STDBY-4-CONFREG_BREAK_ENABLED: The default factory setting for config register is 0x2102.It is advisable to retain 1 in 0x2102 as it prevents returning to ROMMON when break is issued.
000036: *Apr 27 06:50:40.171: %SPANTREE-SP-STDBY-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Apr 27 06:50:40.387: SP-STDBY: SP: Currently running ROMMON from S (Gold) region
000037: *Apr 27 06:50:44.715: %C7600_PLATFORM-SP-STDBY-4-CONFREG_BREAK_ENABLED: The default factory setting for config register is 0x2102.It is advisable to retain 1 in 0x2102 as it prevents returning to ROMMON when break is issued.
000038: *Apr 27 06:50:45.047: %DIAG-SP-STDBY-6-RUN_MINIMUM: Module 6: Running Minimal Diagnostics...
000039: *Apr 27 06:50:45.959: %DIAG-SP-STDBY-6-DIAG_OK: Module 6: Passed Online Diagnostics
000040: *Apr 27 06:51:35.879: %SYS-SP-STDBY-5-RESTART: System restarted --
000041: *Apr 27 14:51:49.075 GMT: %HSRP-5-STATECHANGE: Vlan601 Grp 61 state Standby -> Active
000042: *Apr 27 14:51:52.823 GMT: %HA_CONFIG_SYNC-6-BULK_CFGSYNC_SUCCEED: Bulk Sync succeeded
000043: *Apr 27 14:51:52.327 GMT: %PFREDUN-SP-STDBY-6-STANDBY: Ready for SSO mode
000044: *Apr 27 14:51:53.699 GMT: %RF-SP-5-RF_TERMINAL_STATE: Terminal state reached for (SSO)
000045: *Apr 27 14:52:12.539 GMT: %DIAG-SP-6-DIAG_OK: Module 9: Passed Online Diagnostics
000046: *Apr 27 14:52:21.579 GMT: %DIAG-SP-6-DIAG_OK: Module 2: Passed Online Diagnostics
000047: *Apr 27 14:52:25.511 GMT: %OIR-SP-6-INSCARD: Card inserted in slot 2, interfaces are now online
000048: *Apr 27 14:52:32.127 GMT: %DIAG-SP-6-DIAG_OK: Module 3: Passed Online Diagnostics
*Apr 27 14:52:32.535 GMT: SP: PREDNLD: LC doesn't meet resource requirement for pre-download, not reserving memory for slot 3
000049: *Apr 27 14:52:32.931 GMT: %OIR-SP-6-INSCARD: Card inserted in slot 9, interfaces are now online
000050: *Apr 27 14:52:39.627 GMT: %DIAG-SP-6-DIAG_OK: Module 4: Passed Online Diagnostics
*Apr 27 14:52:40.083 GMT: SP: PREDNLD: LC doesn't meet resource requirement for pre-download, not reserving memory for slot 4
000051: *Apr 27 14:52:44.291 GMT: %OIR-SP-6-INSCARD: Card inserted in slot 3, interfaces are now online
000052: *Apr 27 14:52:51.559 GMT: %OIR-SP-6-INSCARD: Card inserted in slot 4, interfaces are now online
sw6#
Alvaro Garcia
This message appears from SP. Not sure what type of card you have on slot 2, probably a 67xx. Those cards are eFSU supported cards but must have min 512MB of memory to pre download the image so that it goes for soft reset during efsu upgrade . If it has less than 512MB memory then it will go for hard reset during the upgrade. Also during every reset of the card you will encounter this message until you upgrade the memory to 512MB. IMO, if you are not doing efsu upgrade, this message is harmless and just an indication of inadequate LC memory for efsu upgrade.
