any solution
Firass.elheilani
Frequent Visitor
Frequent Visitor
31-May-2018 03:44:26 %AAA-I-CONNECT: New http connection for user cisco, source 172.23.189.150 destination 172.23.189.130 ACCEPTED
31-May-2018 03:45:09 %AAA-I-CONNECT: New https connection for user cisco, source 172.23.189.150 destination 172.23.189.130 ACCEPTED
31-May-2018 03:45:38 %AAA-I-DISCONNECT: http connection for user cisco, source 172.23.189.150 destination 172.23.189.130 TERMINATED
 everytime I try to be connected by HTTP after 15 sec I will be out any solution to désactive this thing plz?
Georg Pauwen
what device is this on ? Post the full config...
What browser are you using ?
Mark Malone
what is the global HTTP config on this device 172.23.189.130
check there is not a timeout like below config
sh run | i http
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/https/configuration/12-2sy/https-12-2sy-book/nm-http-web.html
Step 10
ip http timeout-policy idle seconds life seconds requests value
Example:
Router(config)# ip http timeout-policy idle 30 life 120 requests 100
(Optional) Sets the characteristics that determine how long a connection to the HTTP server should remain open. The characteristics include the following:
idle—The maximum number of seconds the connection will be kept open if no data is received or if response data cannot be sent out on the connection. Note that a new value may not take effect on any already existing connections. If the server is too busy or the limit on the life time or the number of requests is reached, the connection may be closed sooner. The default value is 180 seconds (3 minutes).
life—The maximum number of seconds the connection will be kept open, from the time the connection is established. Note that the new value may not take effect on any already existing connections. If the server is too busy or the limit on the idle time or the number of requests is reached, it may close the connection sooner. Also, since the server will not close the connection while actively processing a request, the connection may remain open longer than the specified life time if processing is occurring when the life maximum is reached. In this case, the connection will be closed when processing finishes. The default value is 180 seconds (3 minutes). The maximum value is 86400 seconds (24 hours).
requests—The maximum limit on the number of requests processed on a persistent connection before it is closed. Note that the new value may not take effect on already existing connections. If the server is too busy or the limit on the idle time or the life time is reached, the connection may be closed before the maximum number of requests are processed. The default value is 1. The maximum value is 86400.
