Any way to know the power failure history from 2960x switch
mohammad saeed
Level 5
Level 5
Hi Guys,
I have stack switch the power is not stable on them and I want to show the technician the logs about switch restarted time...is there any way to know that?
Thanks for all
MK saeed
7 Replies 7
Reza Sharifi
When the switch is rebooted, all logs will clear unless you log to a syslog server, Splunk, etc..
You can always look at the "sh ver" after the reboot and that will tell you how long the switch has been up and running.
Can i see it from interface up link up/down history?
Interface up and down is usually in logs as well. So, if the switch is rebooted, that info is not there anymore.
OK. what about if I want to check from core switch the uplink interface which is connected to switch can I check the up/down history from 6800 core switch?
Thanks for support
That's another way but it's not reliable?
How do you know if it's a power outage or a link flap?
because I know the time of power failure but I don't have the evidence. so I want to know the uplink of interface hostory.
Leo Laohoo
No way.
