archive feature on router and tftp
sarahr202
Level 5
Level 5
Hi everybody.
I am trying to learn how " archive" feature works.
R1----------------------------tftp
In above set up:
R1 --- 199.199.199.1
tftp----199.199.199.10
I am able  to copy running-config to tftp as shown below:
R1#copy running-config tftp
Address or name of remote host []? 199.199.199.10
Destination filename [r1-confg]?
811 bytes copied in 15.008 secs (54 bytes/sec
Next  I add following config  to R1:
R1(config)#archive
R1(config-archive)#path tftp:199.199.199.10 ?
  <cr>
R1(config-archive)#time-period ?
  <1-525600>  Number of minutes to wait between archive creation
R1(config-archive)#time-period 1
R1(config-archive)#end
Based on the above config,R1 will copy its startup-config to tftp every minute. However, R1 is keeping generating this message:
R1#
%Error opening tftp:///199.199.199.10-1 (Invalid IP address or hostname)
When i use the command "  copy running-config tftp " on R1, everything things works fine. R1 is able to copy running config to tftp . But when i  used the archive feature, R1 generates a message as shown above.
What did i do wrong ?
thanks and have a great weekend.
Giuseppe Larosa
Hello Sarah,
a // is required after tftp: and before the TFTP server IP address in the path command because it is an URL
see
http://www.cisco.com/en/US/docs/ios-xml/ios/fundamentals/command/monitor_event-trace_through_Q.html#GUID-ED751541-E00C-4B40-9261-D6722B6CE7B8
The following example show how to create the configuration archive, save  the running configuration to the archive, and display the files in the  archive:
configure terminal
archive
 path tftp://10.48.71.226/router-cfg
 exit
exit
Hope to help
Giuseppe
Giuseppe Larosa
Hello Sarah,
see
configure terminal
archive
 exit
exit
Hope to help
Giuseppe
I need some more explanation on  following commands
Router(config-archive)# ?
Archive configuration commands:
  default            Set a command to its defaults
  exit               Exit from archive configuration mode
  log                Logging commands
  maximum            Maximum number of backup copies
  no                 Negate a command or set its defaults
  path               Path for backups
  rollback           Rollback parameters
  time-period        Period of time in minutes to automatically archive
the running-config
  write-memory       Enable automatic backup generation during
write memory
and also i am enable archive features.. It weas adding the temestamp after every file name..
for  eg i schedule back for 10 minutes. in name of router-cfg,   automatic back up first file was router-cfgDec-20-13.31-12.267 what is this. How it was assuming the name with timestamp.. I need to do like router-cfg 1,2,3 so and so on.. Kindly help with explaing the each commands.. and also if there any automatic restoration tool was available ?
cliffordgunnee
path tftp://<ip address>/$h$t.txt
This should do it
