Are BPDUs Only on Cisco Switches?
davidhuynh5
Or are bpdu open standard that can be on other vendor switches such as 3com, Linksys, Netgear, etc. Thanks.
3 Accepted Solutions
sdheer
BPDUs are open standard that can be on other 3rd party switches as well
Leo Laohoo
I agree.
All switches talk BPDU.
Joseph W. Doherty
Disclaimer
The Author of this posting  offers the information contained within this  posting without  consideration and with the reader's understanding that  there's no  implied or expressed suitability or fitness for any purpose.    Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind.  Usage of   this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever   (including, without limitation, damages for loss of use, data or  profit)  arising out of the use or inability to use the posting's  information  even if Author has been advised of the possibility of such  damage.
Posting
The standards are open, but you do need to be aware that not all equipment supports the same versions of STP that uses them.
Also, when Leo notes "All switches talk BPDU.", also keep in mind non-managed switches don't run STP.  Such switches will pass the BPDUs along, but you can loop your L2 topology on such a single switch or a combination of such joined switches.
5 Replies 5
sdheer
Leo Laohoo
I agree.
Joseph W. Doherty
Disclaimer
Posting
Hi Joseph,
ad "non-managed switches don't run STP")
So far I thought as Leo all switches were running STP (802.1d at least)?
Maybe I was not buying the right "supercheap" ones, but have you really met a switch not running any STP?
Milan
Leo Laohoo
Thanks for the ratings David.
