Arp inspection issue
alioune-ndiaye
Hello Guys,
I have an irror message: err-disabled.
The PCs get their Ip from the DHCP.
Troubleshooting
I did  some troubleshooting:
Switch#sh interfaces status err-disabled
Port      Name               Status       Reason               Err-disabled Vlans
Gi1/0/30  Port_PC            err-disabled arp-inspection
Gi4/0/39  Port_PC            err-disabled arp-inspection
Action plan
I configured
Switch(config)# errdisable recovery cause arp-inspection
Question
How can I fix the issue once and fore all?
Thank u
Alioune
2 Accepted Solutions
Can you post the output of the commands I asked above.
Alain.
you didn't send sh ip dhcp snooping bind output.
Regards.
Alain.
11 Replies 11
Hi Alioune,
Why you need to configure err-disable the port facing the PCs.
I would suggest, disable err-disable on port basis (ports facing PCs)
Smitesh
Hello Smitesh,
I do not want to do shutdown /no shutdown everytime when I have err-disabled due to arp inspection.
That's why I configured errdisable recovery cause arp-inspection to auto recovery in case of   arp inspection.
Thank u
Alioune
Hi Alioune,
What i meant was to disable errdisable.
no errdisable
Smitesh
cadet alain
can you post sh run | i  arp ,  sh ip arp inspection interface , sh ip arp inspection vlan  and sh ip dhcp snooping binding
Regards.
Alain.
Alain.
Why did you rate this question? did it help you solve the problem?
Alain.
Hello Alain
It was a mistake, sorry.
Here are the outputs that you requested:
Switch#s    show run | incl arp
ip arp inspection vlan 1-207,209-997,999-4094
ip arp inspection trust
Switch#
Switch#sh ip arp inspec inter               vlan 1
Source Mac Validation      : Disabled
Destination Mac Validation : Disabled
IP Address Validation      : Disabled
Vlan     Configuration    Operation   ACL Match          Static ACL
    1     Enabled          Active
Vlan     ACL Logging      DHCP Logging      Probe Logging
    1     Deny             Deny              Off
Switch#
Switch#sh ip arp inspec vlan 1                  stat
Vlan      Forwarded        Dropped     DHCP Drops      ACL Drops
    1           1901            196            196              0
    2              0              0              0              0
    3              0              0              0              0
    4              0              0              0              0
    5              0              0              0              0
    6              0              0              0              0
    7              0              0              0              0
    8              0              0              0              0
    9              0              0              0              0
   10              0              0              0              0
   11              0              0              0              0
   12              0              0              0              0
   13              0              0              0              0
   14              0              0              0              0
   15              0              0              0              0
   16              0              0              0              0
   17              0              0              0              0
   18              0              0              0              0
   19              0              0              0              0
   20              0              0              0              0
Interface        Trust State     Rate (pps)    Burst Interval
Gi1/0/1          Untrusted               15                 1
Gi1/0/2          Untrusted               15                 1
Gi1/0/3          Untrusted               15                 1
Gi1/0/4          Untrusted               15                 1
Gi1/0/5          Untrusted               15                 1
Gi1/0/6          Untrusted               15                 1
Gi1/0/7          Untrusted               15                 1
Gi1/0/8          Untrusted               15                 1
Gi1/0/9          Untrusted               15                 1
Gi1/0/10         Untrusted               15                 1
Gi1/0/11         Untrusted               15                 1
Gi1/0/12         Untrusted               15                 1
Gi1/0/13         Untrusted               15                 1
Gi1/0/14         Untrusted               15                 1
Gi1/0/15         Untrusted               15                 1
Gi1/0/16         Untrusted               15                 1
Gi1/0/17         Untrusted               15                 1
Gi1/0/18         Untrusted               15                 1
Gi1/0/19         Untrusted               15                 1
Gi1/0/20         Untrusted               15                 1
--More--                            Gi1/0/21         Trusted               None               N/A
--More--                            Gi1/0/22         Untrusted               15                 1
--More--                            Gi1/0/23         Untrusted               15                 1
--More--                            Gi1/0/24         Untrusted               15                 1
--More--                            Gi1/0/25         Untrusted               15                 1
--More--                            Gi1/0/26         Untrusted               15                 1
--More--                            Gi1/0/27         Untrusted               15                 1
--More--                            Gi1/0/28         Untrusted               15                 1
--More--                            Gi1/0/29         Untrusted               15                 1
--More--                            Gi1/0/30         Untrusted               15                 1
--More--                            Gi1/0/31         Untrusted               15                 1
--More--                            Gi1/0/32         Trusted               None               N/A
--More--                            Gi1/0/33         Trusted               None               N/A
--More--                            Gi1/0/34         Trusted               None               N/A
--More--                            Gi1/0/35         Trusted               None               N/A
--More--                            Gi1/0/36         Untrusted               15                 1
--More--                            Gi1/0/37         Trusted               None               N/A
--More--                            Gi1/0/38         Untrusted               15                 1
--More--                            Gi1/0/39         Untrusted               15                 1
--More--                            Gi1/0/40         Untrusted               15                 1
--More--                            Gi1/0/41         Untrusted               15                 1
--More--                            Gi1/0/42         Untrusted               15                 1
--More--                            Gi1/0/43         Untrusted               15                 1
--More--                            Gi1/0/44         Untrusted               15                 1
--More--                            Gi1/0/45         Untrusted               15                 1
--More--                            Gi1/0/46         Untrusted               15                 1
--More--                            Gi1/0/47         Untrusted               15                 1
--More--                            Gi1/0/48         Untrusted               15                 1
--More--                            Gi1/0/49         Untrusted               15                 1
--More--                            Gi1/0/50         Untrusted               15                 1
--More--                            Gi1/0/51         Untrusted               15                 1
--More--                            Gi1/0/52         Untrusted               15                 1
--More--                            Te1/0/1          Trusted               None               N/A
--More--                            Te1/0/2
Thank u
Regards.
Alain.
Alain,
Sorry,
Regarding the biding table I  do not see any entries  with vlan 1 otherwise we have so many entries around 395.
SW-MAF-TER-1-LTT1-1-05#sh ip dhcp snoo bin
MacAddress          IpAddress        Lease(sec)  Type           VLAN  Interface
00:1C:23:03:51:04   10.65.7.141      442510      dhcp-snooping   104   GigabitEthernet2/0/45
B4:B0:17:8E:38:58   10.65.107.80     447850      dhcp-snooping   204   FastEthernet7/0/9
00:21:70:F4:8B:CC   10.65.7.138      676984      dhcp-snooping   104   GigabitEthernet2/0/6
B4:B0:17:8E:38:41   10.65.107.119    627582      dhcp-snooping   204   GigabitEthernet5/0/19
00:1C:23:12:48:BB   10.65.7.69       603160      dhcp-snooping   104   GigabitEthernet3/0/37
D0:67:E5:35:80:B2   10.65.7.62       589781      dhcp-snooping   104   GigabitEthernet4/0/24
00:21:70:EE:91:C5   10.65.150.65     159478      dhcp-snooping   997   GigabitEthernet2/0/43
B4:B0:17:8E:3B:AB   10.65.107.79     447879      dhcp-snooping   204   FastEthernet7/0/16
F0:4D:A2:35:CE:E6   10.65.7.4        685366      dhcp-snooping   104   GigabitEthernet1/0/26
00:11:43:18:6A:2D   101.100.100.51   52248       dhcp-snooping   129   FastEthernet6/0/23
--More--                           B4:B0:17:89:7E:B5   10.65.107.104    619238      dhcp-snooping   204   GigabitEthernet5/0/7
--More--                           00:1C:23:39:7F:AF   10.65.7.43       678062      dhcp-snooping   104   GigabitEthernet3/0/29
--More--                           B4:B0:17:8E:38:86   10.65.107.63     601076      dhcp-snooping   204   FastEthernet7/0/29
--More--                           00:21:70:F4:8A:24   101.100.100.86   15057       dhcp-snooping   129   GigabitEthernet4/0/31
--More--                           00:1A:A0:22:9F:07   10.65.150.23     161729      dhcp-snooping   997   GigabitEthernet3/0/36
--More--                           BC:30:5B:C8:11:9F   10.65.7.32       670480      dhcp-snooping   104   GigabitEthernet1/0/43
--More--                           B4:B0:17:89:7E:5B   10.65.107.135    677602      dhcp-snooping   204   GigabitEthernet5/0/32
--More--                           B4:B0:17:8E:0D:43   10.65.107.100    610198      dhcp-snooping   204   GigabitEthernet5/0/2
--More--                           00:1D:09:1E:F5:B4   10.65.7.147      676533      dhcp-snooping   104   GigabitEthernet2/0/4
--More--                           F0:4D:A2:28:DC:52   10.65.7.90       616946      dhcp-snooping   104   GigabitEthernet4/0/24
--More--                           B4:B0:17:8E:38:59   10.65.107.54     445667      dhcp-snooping   204   FastEthernet7/0/30
--More--                           B8:AC:6F:49:C7:16   10.65.7.67       613662      dhcp-snooping   104   GigabitEthernet3/0/41
--More--                           F0:4D:A2:FB:C2:DC   10.65.7.170      673330      dhcp-snooping   104   GigabitEthernet3/0/7
--More--                           78:2B:CB:CA:A7:DD   10.65.7.16       679905      dhcp-snooping   104   GigabitEthernet1/0/33
--More--                           F0:4D:A2:FB:BD:FB   10.65.150.8      91330       dhcp-snooping   997   GigabitEthernet3/0/34
--More--                           00:21:70:B2:71:4A   10.65.7.122      676408      dhcp-snooping   104   GigabitEthernet5/0/40
--More--                           B4:B0:17:89:7C:82   10.65.107.75     687876      dhcp-snooping   204   FastEthernet8/0/10
--More--                           BC:30:5B:9E:52:BB   10.65.7.115      677904      dhcp-snooping   104   GigabitEthernet1/0/42
--More--                           B4:B0:17:89:7E:3B   10.65.107.50     529683      dhcp-snooping   204   FastEthernet6/0/8
--More--                           00:80:77:D9:11:7F   10.65.32.6       353568      dhcp-snooping   115   FastEthernet6/0/47
--More--                           00:21:70:EE:91:C5   10.65.7.48       677759      dhcp-snooping   104   GigabitEthernet2/0/43
--More--                           F0:4D:A2:FB:C2:DA   10.65.7.49       677908      dhcp-snooping   104   GigabitEthernet2/0/18
--More--                           B4:B0:17:98:E2:AC   10.65.107.26     592530      dhcp-snooping   204   FastEthernet6/0/5
--More--                           B4:B0:17:8E:0D:58   10.65.107.113    596865      dhcp-snooping   204   FastEthernet8/0/12
--More--                           00:26:B9:BE:8B:73   101.100.100.104  75670       dhcp-snooping   129   GigabitEthernet1/0/36
--More--                           00:21:9B:61:36:B1   10.65.7.14       676536      dhcp-snooping   104   GigabitEthernet3/0/20
--More--                           B4:B0:17:89:7E:AB   10.65.107.137    601543      dhcp-snooping   204   GigabitEthernet5/0/34
--More--                           F0:4D:A2:89:68:FE   10.65.7.97       616197      dhcp-snooping   104   GigabitEthernet1/0/25
--More--                           F0:4D:A2:D0:7F:C2   101.100.100.114  3697        dhcp-snooping   129   GigabitEthernet3/0/45
--More--                           00:1C:23:13:85:9E   10.65.7.77       20336       dhcp-snooping   104   GigabitEthernet1/0/36
--More--                           B4:B0:17:89:7E:C4   10.65.107.15     362367      dhcp-snooping   204   FastEthernet6/0/31
--More--                           B4:B0:17:8E:0D:14   10.65.107.27     355640      dhcp-snooping   204   FastEthernet7/0/18
--More--                           F0:4D:A2:D0:7F:C2   10.65.150.46     168807      dhcp-snooping   997   GigabitEthernet3/0/45
--More--                           B4:B0:17:8E:38:56   10.65.107.82     447804      dhcp-snooping   204   FastEthernet7/0/11
--More--                           00:19:B9:0E:CC:4D   10.65.7.104      622210      dhcp-snooping   104   GigabitEthernet4/0/24
--More--                           B4:B0:17:89:7E:7D   10.65.107.91     530152      dhcp-snooping   204   FastEthernet7/0/21
--More--                           00:23:AE:A8:2A:DE   10.65.150.4      91824       dhcp-snooping   997   GigabitEthernet1/0/31
--More--                           78:2B:CB:CA:A7:DD   10.65.150.21     172708      dhcp-snooping   997   GigabitEthernet1/0/33
--More--                           B4:B0:17:89:7E:8E   10.65.107.125    601555      dhcp-snooping   204   GigabitEthernet5/0/31
--More--                           B4:B0:17:8E:38:2D   10.65.107.96     511068      dhcp-snooping   204   FastEthernet8/0/2
--More--                           00:1E:C9:44:21:67   10.65.150.14     157636      dhcp-snooping   997   GigabitEthernet1/0/32
--More--                           00:1E:C9:50:E6:F8   10.65.150.2      158328      dhcp-snooping   997   GigabitEthernet1/0/28
--More--                           F0:4D:A2:FA:60:FA   10.65.32.5       2145        dhcp-snooping   115   GigabitEthernet4/0/47
--More--                           00:21:70:A4:A9:6C   10.65.7.136      678859      dhcp-snooping   104   GigabitEthernet3/0/13
--More--                           B4:B0:17:89:7E:A8   10.65.107.87     420217      dhcp-snooping   204   FastEthernet7/0/8
--More--                           00:1E:C9:50:F7:B3   10.65.7.29       674331      dhcp-snooping   104   GigabitEthernet3/0/2
--More--                           BC:30:5B:9E:53:CB   10.65.7.73       679484      dhcp-snooping   104   GigabitEthernet3/0/16
--More--                           F0:4D:A2:FB:C2:F0   10.65.7.53       679383      dhcp-snooping   104   GigabitEthernet2/0/24
--More--                           00:21:70:91:A9:84   10.65.7.6        677822      dhcp-snooping   104   GigabitEthernet4/0/24
--More--                           00:1C:23:0E:E0:E6   10.65.7.94       592680      dhcp-snooping   104   GigabitEthernet2/0/32
--More--                           5C:26:0A:4D:36:1A   10.65.150.10     72016       dhcp-snooping   997   GigabitEthernet4/0/42
--More--                           00:21:70:B0:52:F4   10.65.7.118      590120      dhcp-snooping   104   GigabitEthernet4/0/27
--More--                           B4:B0:17:8E:38:90   10.65.107.102    353100      dhcp-snooping   204   GigabitEthernet5/0/13
--More--                           F0:4D:A2:FA:60:FA   10.65.7.145      591834      dhcp-snooping   104   GigabitEthernet4/0/47
--More--                           00:21:70:A4:A9:D5   10.65.7.157      681449      dhcp-snooping   104   GigabitEthernet1/0/16
--More--                           B4:B0:17:8E:0D:3A   10.65.107.127    436300      dhcp-snooping   204   GigabitEthernet5/0/37
--More--                           B4:B0:17:8E:37:EA   10.65.107.103    424318      dhcp-snooping   204   GigabitEthernet5/0/12
--More--                           00:1B:4F:4E:4F:67   10.65.107.4      611973      dhcp-snooping   204   GigabitEthernet3/0/48
--More--                           00:1A:A0:22:AF:0B   10.65.7.93       679676      dhcp-snooping   104   GigabitEthernet3/0/11
--More--                           B4:B0:17:8E:0D:7B   10.65.107.20     673944      dhcp-snooping   204   FastEthernet6/0/25
--More--                           00:18:8B:CE:C2:0F   10.65.150.16     159057      dhcp-snooping   997   GigabitEthernet2/0/28
--More--                           00:1C:23:39:7F:AF   10.65.150.42     159959      dhcp-snooping   997   GigabitEthernet3/0/29
--More--                           B4:B0:17:8E:38:73   10.65.107.74     424964      dhcp-snooping   204   FastEthernet8/0/17
--More--                           B4:B0:17:8E:0D:44   10.65.107.10     363223      dhcp-snooping   204   FastEthernet7/0/40
--More--                           00:24:E8:C6:40:70   10.65.7.71       160141      dhcp-snooping   104   GigabitEthernet1/0/36
--More--                           B4:B0:17:89:7E:C5   10.65.107.51     355559      dhcp-snooping   204   FastEthernet7/0/22
--More--                           B4:B0:17:8E:37:BA   10.65.107.76     447646      dhcp-snooping   204   FastEthernet8/0/11
--More--                           B4:B0:17:89:7D:3C   10.65.107.11     349520      dhcp-snooping   204   FastEthernet6/0/11
--More--                           78:2B:CB:D5:AE:DD   10.65.150.19     159339      dhcp-snooping   997   GigabitEthernet2/0/15
--More--                           20:6A:8A:33:0C:AA   10.65.150.52     167946      dhcp-snooping   997   GigabitEthernet3/0/30
--More--                           B4:B0:17:89:7E:8D   10.65.107.72     447295      dhcp-snooping   204   FastEthernet8/0/16
--More--                           F0:4D:A2:2C:70:BA   10.65.7.151      679723      dhcp-snooping   104   GigabitEthernet4/0/3
--More--                           B4:B0:17:8E:0D:50   10.65.107.29     527108      dhcp-snooping   204   FastEthernet8/0/27
--More--                           00:1B:4F:71:C3:07   10.65.107.134    612308      dhcp-snooping   204   GigabitEthernet5/0/26
--More--                           B8:AC:6F:C9:CB:AC   10.65.150.12     169034      dhcp-snooping   997   GigabitEthernet3/0/42
--More--                           00:21:9B:61:33:D0   10.65.150.44     166817      dhcp-snooping   997   GigabitEthernet1/0/38
--More--                           00:1C:23:1C:14:4E   10.65.7.31       677765      dhcp-snooping   104   GigabitEthernet4/0/37
--More--                           B4:B0:17:8E:38:A1   10.65.107.106    419892      dhcp-snooping   204   GigabitEthernet5/0/6
--More--                           B4:B0:17:88:24:86   10.65.107.66     515055      dhcp-snooping   204   FastEthernet8/0/34
--More--                           00:21:70:94:91:C8   10.65.7.55       681435      dhcp-snooping   104   GigabitEthernet3/0/43
--More--                           B4:B0:17:8E:0D:76   10.65.107.35     350159      dhcp-snooping   204   FastEthernet6/0/10
--More--                           B4:B0:17:8E:0D:5D   10.65.107.49     592873      dhcp-snooping   204   FastEthernet8/0/36
--More--                           00:21:70:F4:8C:39   10.65.150.30     164578      dhcp-snooping   997   GigabitEthernet1/0/29
--More--                           F0:4D:A2:35:CE:E6   10.65.150.20     166972      dhcp-snooping   997   GigabitEthernet1/0/26
--More--                           00:20:6B:64:0B:66   10.65.32.108     420593      dhcp-snooping   115   GigabitEthernet5/0/47
--More--                           00:15:99:43:EF:89   10.65.32.4       430053      dhcp-snooping   115   FastEthernet7/0/47
--More--                           B4:B0:17:8E:38:65   10.65.107.89     521680      dhcp-snooping   204   FastEthernet8/0/21
--More--                           00:24:E8:C0:37:EA   10.65.7.5        680551      dhcp-snooping   104   GigabitEthernet4/0/39
--More--                           00:1F:F3:CF:2E:49   10.65.7.9        673174      dhcp-snooping   104   GigabitEthernet4/0/24
--More--                           B4:B0:17:8E:0D:C1   10.65.107.12     589795      dhcp-snooping   204   FastEthernet6/0/32
--More--                           B4:B0:17:89:7E:81   10.65.107.70     354881      dhcp-snooping   204   FastEthernet7/0/7
--More--                           B4:B0:17:8E:37:45   10.65.107.53     614352      dhcp-snooping   204   FastEthernet7/0/28
--More--                           B4:B0:17:8E:0D:6B   10.65.107.42     524886      dhcp-snooping   204   FastEthernet8/0/31
--More--                           00:22:BD:6C:C8:C0   10.65.7.41       450447      dhcp-snooping   104   GigabitEthernet4/0/24
--More--                           00:1B:4F:4E:4F:FE   10.65.107.146    682362      dhcp-snooping   204   GigabitEthernet4/0/26
--More--                           00:14:22:CE:73:E1   10.65.150.33     161378      dhcp-snooping   997   GigabitEthernet2/0/35
--More--                           00:18:8B:C1:DA:44   10.65.7.44       188641      dhcp-snooping   104   GigabitEthernet1/0/25
--More--                           00:24:7E:68:13:D2   10.65.150.68     74814       dhcp-snooping   997   GigabitEthernet2/0/33
--More--                           78:2B:CB:CB:F5:95   10.65.7.2        677006      dhcp-snooping   104   GigabitEthernet2/0/25
--More--                           B4:B0:17:8E:0D:4A   10.65.107.69     529099      dhcp-snooping   204   FastEthernet6/0/34
--More--                           00:1C:23:39:7F:A8   10.65.150.51     71458       dhcp-snooping   997   GigabitEthernet3/0/32
--More--                           B4:B0:17:98:F8:19   10.65.107.138    681606      dhcp-snooping   204   GigabitEthernet5/0/27
--More--                           00:1E:C9:44:21:67   10.65.7.28       549715      dhcp-snooping   104   GigabitEthernet1/0/32
--More--                           00:26:B9:BE:8B:73   10.65.7.1        681376      dhcp-snooping   104   GigabitEthernet1/0/36
--More--                           78:2B:CB:E9:9C:C1   101.100.100.13   16645       dhcp-snooping   129   GigabitEthernet1/0/1
--More--                           00:1E:C9:4F:C8:5F   10.65.7.80       676659      dhcp-snooping   104   GigabitEthernet2/0/23
--More--                           00:24:E8:E0:87:0A   10.65.150.32     171415      dhcp-snooping   997   GigabitEthernet2/0/36
--More--                           F0:4D:A2:35:D6:A2   10.65.7.160      521171      dhcp-snooping   104   GigabitEthernet4/0/24
--More--                           B4:B0:17:8E:0D:B7   10.65.107.14     620235      dhcp-snooping   204   FastEthernet6/0/35
--More--                           5C:26:0A:53:FE:88   10.65.7.27       677652      dhcp-snooping   104   GigabitEthernet4/0/15
--More--                           F0:4D:A2:B1:BE:23   101.100.100.18   76316       dhcp-snooping   129   GigabitEthernet2/0/14
--More--                           B8:AC:6F:36:B1:F4   10.65.7.26       679855      dhcp-snooping   104   GigabitEthernet2/0/11
--More--                           00:21:70:F4:7B:CC   10.65.7.24       679246      dhcp-snooping   104   GigabitEthernet3/0/24
--More--                           B4:B0:17:8E:37:CD   10.65.107.83     447847      dhcp-snooping   204   FastEthernet7/0/15
--More--                           B4:B0:17:89:7E:BD   10.65.107.32     592438      dhcp-snooping   204   FastEthernet6/0/42
--More--                           00:1B:4F:71:C3:0B   10.65.107.129    612754      dhcp-snooping   204   GigabitEthernet5/0/9
--More--                           B4:B0:17:89:7E:68   10.65.107.105    438593      dhcp-snooping   204   GigabitEthernet5/0/4
--More--                           00:1D:09:01:A2:FA   10.65.7.165      109149      dhcp-snooping   104   GigabitEthernet4/0/24
--More--                           34:15:9E:06:E0:E2   10.65.7.109      678237      dhcp-snooping   104   GigabitEthernet4/0/4
--More--                           00:1B:4F:71:C1:B8   10.65.107.133    500692      dhcp-snooping   204   GigabitEthernet5/0/14
--More--                           00:1B:4F:71:C3:01   10.65.107.132    684372      dhcp-snooping   204   FastEthernet8/0/23
--More--                           B4:B0:17:8E:38:94   10.65.107.9      598645      dhcp-snooping   204   FastEthernet6/0/38
--More--                           E8:9D:87:5C:75:1F   10.65.7.155      675949      dhcp-snooping   104   GigabitEthernet1/0/17
--More--                           00:1E:C9:2D:6F:D6   10.65.7.111      680050      dhcp-snooping   104   GigabitEthernet2/0/46
--More--                           00:1E:C9:4F:C4:1A   10.65.7.79       679302      dhcp-snooping   104   GigabitEthernet4/0/6
--More--                           B4:B0:17:89:7E:A2   10.65.107.81     592525      dhcp-snooping   204   FastEthernet7/0/10
--More--                           B4:B0:17:8E:0C:59   10.65.107.55     593901      dhcp-snooping   204   FastEthernet7/0/33
--More--                           B4:B0:17:89:7E:61   10.65.107.39     601484      dhcp-snooping   204   FastEthernet7/0/34
--More--                           D0:67:E5:39:4C:2F   10.65.7.152      614233      dhcp-snooping   104   GigabitEthernet5/0/42
--More--                           00:1E:4F:B2:7E:B6   10.65.150.58     107069      dhcp-snooping   997   GigabitEthernet3/0/26
--More--                           00:1D:09:01:69:5A   10.65.7.76       429875      dhcp-snooping   104   GigabitEthernet3/0/9
--More--                           B4:B0:17:8E:38:7E   10.65.107.117    626840      dhcp-snooping   204   GigabitEthernet5/0/17
--More--                           F0:4D:A2:35:D3:85   10.65.7.87       680615      dhcp-snooping   104   GigabitEthernet3/0/19
--More--                           B8:AC:6F:45:66:F6   10.65.7.84       514913      dhcp-snooping   104   GigabitEthernet2/0/20
--More--                           A4:BA:DB:DE:00:06   10.65.7.143      686736      dhcp-snooping   104   GigabitEthernet4/0/23
--More--                           00:1C:23:39:7F:AA   10.65.7.37       669962      dhcp-snooping   104   GigabitEthernet3/0/33
--More--                           B4:B0:17:8E:1B:15   10.65.107.95     642034      dhcp-snooping   204   FastEthernet8/0/1
--More--                           D0:67:E5:0C:BE:37   10.65.7.130      527062      dhcp-snooping   104   GigabitEthernet4/0/24
--More--                           00:21:70:A4:A9:66   10.65.7.21       507430      dhcp-snooping   104   GigabitEthernet2/0/16
--More--                           B4:B0:17:89:7E:B3   10.65.107.31     686905      dhcp-snooping   204   FastEthernet8/0/42
--More--                           00:21:70:A4:A9:D5   10.65.150.40     168279      dhcp-snooping   997   GigabitEthernet1/0/16
--More--                           00:1B:4F:4E:4F:4D   10.65.107.7      680342      dhcp-snooping   204   GigabitEthernet4/0/48
--More--                           B4:B0:17:98:E7:1B   10.65.107.22     416560      dhcp-snooping   204   FastEthernet6/0/39
--More--                           00:1D:09:05:B9:F5   10.65.150.28     167170      dhcp-snooping   997   GigabitEthernet2/0/37
--More--                           BC:30:5B:AD:0F:8B   10.65.7.83       678396      dhcp-snooping   104   GigabitEthernet4/0/7
--More--                           B4:B0:17:89:7E:C6   10.65.107.5      611914      dhcp-snooping   204   FastEthernet7/0/36
--More--                           00:24:7E:6A:43:2E   10.65.150.48     71038       dhcp-snooping   997   GigabitEthernet2/0/27
--More--                           B4:B0:17:8E:0D:B2   10.65.107.64     364181      dhcp-snooping   204   FastEthernet7/0/41
--More--                           B8:AC:6F:C6:75:A8   10.65.7.7        668168      dhcp-snooping   104   GigabitEthernet1/0/39
--More--                           B4:B0:17:8E:37:D0   10.65.107.58     446614      dhcp-snooping   204   FastEthernet7/0/19
--More--                           00:15:C5:59:E4:77   10.65.150.53     79063       dhcp-snooping   997   GigabitEthernet1/0/12
--More--                           BC:30:5B:AD:1E:BF   10.65.7.101      7351        dhcp-snooping   104   GigabitEthernet1/0/6
--More--                           00:24:E8:CF:B6:68   10.65.150.54     20578       dhcp-snooping   997   GigabitEthernet1/0/36
--More--                           F0:4D:A2:35:CF:95   10.65.7.61       679012      dhcp-snooping   104   GigabitEthernet1/0/9
--More--                           B4:B0:17:8E:0D:68   10.65.107.144    508719      dhcp-snooping   204   GigabitEthernet5/0/25
--More--                           00:15:C5:44:1C:8E   10.65.7.18       682006      dhcp-snooping   104   GigabitEthernet1/0/18
--More--                           BC:30:5B:9E:DB:42   10.65.7.78       621129      dhcp-snooping   104   GigabitEthernet1/0/27
--More--                           B4:B0:17:98:DC:9E   10.65.107.23     620367      dhcp-snooping   204   FastEthernet6/0/44
--More--                           B4:B0:17:8E:38:4A   10.65.107.122    627719      dhcp-snooping   204   GigabitEthernet5/0/22
--More--                           00:1E:C9:4F:B7:BD   10.65.7.39       673997      dhcp-snooping   104   GigabitEthernet1/0/23
--More--                           00:1D:09:00:67:9D   10.65.7.106      678104      dhcp-snooping   104   GigabitEthernet4/0/5
--More--                           B4:B0:17:8E:38:5F   10.65.107.36     592815      dhcp-snooping   204   GigabitEthernet5/0/3
--More--                           F0:4D:A2:D3:FF:6C   10.65.7.131      546412      dhcp-snooping   104   GigabitEthernet3/0/21
--More--                           B4:B0:17:89:7D:C4   10.65.107.73     447357      dhcp-snooping   204   FastEthernet8/0/19
--More--                           A4:BA:DB:DD:FF:D6   10.65.7.74       676150      dhcp-snooping   104   GigabitEthernet3/0/14
--More--                           B4:B0:17:8E:37:72   10.65.107.2      618701      dhcp-snooping   204   FastEthernet6/0/36
--More--                           00:24:E8:C8:CC:94   10.65.150.31     76626       dhcp-snooping   997   GigabitEthernet1/0/20
--More--                           B4:B0:17:8E:38:76   10.65.107.109    426459      dhcp-snooping   204   FastEthernet8/0/8
--More--                           B4:B0:17:8D:63:A0   10.65.107.56     593639      dhcp-snooping   204   FastEthernet7/0/42
--More--                           B4:B0:17:8E:38:92   10.65.107.44     680143      dhcp-snooping   204   FastEthernet8/0/32
--More--                           78:2B:CB:7A:3A:C6   10.65.7.3        420499      dhcp-snooping   104   GigabitEthernet1/0/3
--More--                           8C:73:6E:AC:1E:E5   10.65.7.153      94885       dhcp-snooping   104   GigabitEthernet1/0/30
--More--                           F0:4D:A2:D0:7F:C2   10.65.7.12       674814      dhcp-snooping   104   GigabitEthernet3/0/45
--More--                           D0:67:E5:35:5F:E0   10.65.7.20       613896      dhcp-snooping   104   GigabitEthernet2/0/44
--More--                           F0:4D:A2:D0:7F:6E   10.65.7.133      605785      dhcp-snooping   104   GigabitEthernet5/0/41
--More--                           00:1B:4F:4E:4E:E6   10.65.107.145    683049      dhcp-snooping   204   FastEthernet7/0/48
--More--                           B4:B0:17:8E:38:6A   10.65.107.111    624450      dhcp-snooping   204   FastEthernet8/0/18
--More--                           B4:B0:17:8E:38:6E   10.65.107.120    445889      dhcp-snooping   204   GigabitEthernet5/0/20
--More--                           00:1C:23:2C:C2:23   10.65.150.67     160981      dhcp-snooping   997   GigabitEthernet2/0/34
--More--                           B4:B0:17:8E:37:22   10.65.107.136    601983      dhcp-snooping   204   GigabitEthernet1/0/24
--More--                           B4:B0:17:8E:38:48   10.65.107.124    436376      dhcp-snooping   204   GigabitEthernet5/0/35
--More--                           84:2B:2B:B2:28:C4   10.65.7.96       613845      dhcp-snooping   104   GigabitEthernet4/0/24
--More--                           F0:4D:A2:9C:80:46   10.65.7.158      528044      dhcp-snooping   104   GigabitEthernet2/0/3
--More--                           B4:B0:17:8E:37:A2   10.65.107.123    601196      dhcp-snooping   204   GigabitEthernet5/0/36
--More--                           B8:AC:6F:C9:CB:AC   101.100.100.56   73394       dhcp-snooping   129   GigabitEthernet3/0/42
--More--                           00:23:AE:A8:2B:5F   10.65.7.22       354784      dhcp-snooping   104   GigabitEthernet1/0/35
--More--                           78:2B:CB:CA:A7:DD   101.100.100.53   75052       dhcp-snooping   129   GigabitEthernet1/0/33
--More--                           00:23:AE:A8:2A:DE   10.65.7.72       609997      dhcp-snooping   104   GigabitEthernet1/0/31
--More--                           00:1A:A0:22:9F:07   10.65.7.40       623955      dhcp-snooping   104   GigabitEthernet3/0/36
--More--                           00:23:18:90:89:89   10.65.150.37     162557      dhcp-snooping   997   GigabitEthernet3/0/28
--More--                           B4:B0:17:98:EB:7D   10.65.107.28     619290      dhcp-snooping   204   FastEthernet7/0/44
--More--                           00:21:9B:61:33:D0   10.65.7.33       625933      dhcp-snooping   104   GigabitEthernet1/0/38
--More--                           00:1B:4F:71:C2:FA   10.65.107.151    608139      dhcp-snooping   204   FastEthernet6/0/15
--More--                           B4:B0:17:8E:38:68   10.65.107.88     520811      dhcp-snooping   204   FastEthernet7/0/1
--More--                           00:21:D8:47:2D:3C   10.65.117.43     541207      dhcp-snooping   118   FastEthernet7/0/24
--More--                           00:21:70:F4:8A:24   10.65.7.142      678909      dhcp-snooping   104   GigabitEthernet4/0/31
--More--                           B4:B0:17:8E:37:AB   10.65.107.60     508415      dhcp-snooping   204   FastEthernet6/0/6
--More--                           F0:4D:A2:8A:31:BD   10.65.150.36     16783       dhcp-snooping   997   GigabitEthernet1/0/21
--More--                           00:1E:C9:4F:C4:22   10.65.7.102      679272      dhcp-snooping   104   GigabitEthernet4/0/38
--More--                           00:23:18:ED:9C:4B   101.100.100.184  15718       dhcp-snooping   129   GigabitEthernet2/0/25
--More--                           BC:30:5B:9E:D7:D4   10.65.7.148      678464      dhcp-snooping   104   GigabitEthernet4/0/18
--More--                           B4:B0:17:8E:0D:37   10.65.107.92     506004      dhcp-snooping   204   FastEthernet7/0/2
--More--                           B4:B0:17:8E:0D:B1   10.65.107.47     592681      dhcp-snooping   204   FastEthernet8/0/33
--More--                           00:14:22:CE:73:E1   10.65.7.88       679284      dhcp-snooping   104   GigabitEthernet2/0/35
--More--                           B8:AC:6F:C9:CB:AC   10.65.7.34       678245      dhcp-snooping   104   GigabitEthernet3/0/42
--More--                           B4:B0:17:89:7E:55   10.65.107.1      624743      dhcp-snooping   204   FastEthernet6/0/37
--More--                           00:1C:23:1C:05:90   10.65.150.27     161085      dhcp-snooping   997   GigabitEthernet3/0/31
--More--                           F0:4D:A2:D4:01:3C   10.65.7.46       687645      dhcp-snooping   104   GigabitEthernet4/0/27
--More--                           B4:B0:17:8E:0C:D9   10.65.107.90     506150      dhcp-snooping   204   FastEthernet7/0/6
--More--                           5C:26:0A:38:65:5A   101.100.100.41   73497       dhcp-snooping   129   GigabitEthernet3/0/39
--More--                           D4:9A:20:E1:4C:5A   10.65.7.103      512864      dhcp-snooping   104   GigabitEthernet3/0/12
--More--                           B4:B0:17:8E:0D:73   10.65.107.128    600468      dhcp-snooping   204   GigabitEthernet5/0/38
--More--                           00:1C:23:1C:05:78   10.65.7.116      609271      dhcp-snooping   104   GigabitEthernet4/0/33
--More--                           00:1E:C9:50:03:46   10.65.7.60       679798      dhcp-snooping   104   GigabitEthernet1/0/13
--More--                           00:11:43:BA:C4:2B   10.65.7.56       414389      dhcp-snooping   104   GigabitEthernet3/0/35
--More--                           D4:9A:20:E1:40:E8   10.65.7.108      676475      dhcp-snooping   104   GigabitEthernet3/0/17
--More--                           B4:B0:17:8E:0D:83   10.65.107.84     525002      dhcp-snooping   204   FastEthernet8/0/46
--More--                           00:1E:C9:4F:BD:07   10.65.7.99       590073      dhcp-snooping   104   GigabitEthernet4/0/34
--More--                           B4:B0:17:98:F7:B7   10.65.107.24     367269      dhcp-snooping   204   FastEthernet6/0/3
--More--                           B4:B0:17:8E:38:62   10.65.107.114    624728      dhcp-snooping   204   FastEthernet8/0/20
--More--                           00:1E:C9:45:EE:E4   10.65.150.101    155890      dhcp-snooping   997   GigabitEthernet1/0/34
--More--                           00:1D:09:01:69:E2   10.65.7.10       512149      dhcp-snooping   104   GigabitEthernet4/0/24
--More--                           B4:B0:17:8E:0D:34   10.65.107.147    366495      dhcp-snooping   204   FastEthernet7/0/12
--More--                           B4:B0:17:98:E2:95   10.65.107.21     674179      dhcp-snooping   204   FastEthernet6/0/40
--More--                           5C:26:0A:38:65:5A   10.65.150.60     160423      dhcp-snooping   997   GigabitEthernet3/0/39
--More--                           00:1B:4F:4E:4E:F7   10.65.107.101    610523      dhcp-snooping   204   FastEthernet7/0/27
--More--                           78:2B:CB:E9:9C:C1   10.65.150.71     103483      dhcp-snooping   997   GigabitEthernet1/0/1
--More--                           00:11:43:BB:37:EA   10.65.7.11       414436      dhcp-snooping   104   GigabitEthernet4/0/24
--More--                           B4:B0:17:89:7E:4E   10.65.107.37     681233      dhcp-snooping   204   FastEthernet8/0/44
--More--                           B4:B0:17:89:7E:B4   10.65.107.8      677999      dhcp-snooping   204   FastEthernet6/0/1
--More--                           00:1A:A0:20:DE:BD   10.65.7.25       527000      dhcp-snooping   104   GigabitEthernet5/0/44
--More--                           A4:BA:DB:DD:F6:11   10.65.7.105      676666      dhcp-snooping   104   GigabitEthernet2/0/8
--More--                           78:2B:CB:7A:3A:C6   10.65.150.39     102090      dhcp-snooping   997   GigabitEthernet1/0/3
--More--                           F0:4D:A2:FA:64:97   10.65.7.135      608449      dhcp-snooping   104   GigabitEthernet4/0/24
--More--                           B4:B0:17:89:7D:87   10.65.107.71     446617      dhcp-snooping   204   FastEthernet8/0/22
--More--                           00:22:15:84:CD:38   10.65.150.59     96457       dhcp-snooping   997   GigabitEthernet4/0/20
--More--                           00:1B:4F:71:C3:08   10.65.107.149    616601      dhcp-snooping   204   FastEthernet8/0/4
--More--                           B4:B0:17:8E:0D:6D   10.65.107.62     524339      dhcp-snooping   204   FastEthernet8/0/29
--More--                           00:1C:23:55:3F:92   10.65.7.13       436325      dhcp-snooping   104   GigabitEthernet4/0/21
--More--                           00:1E:C9:50:E6:F8   10.65.7.23       676525      dhcp-snooping   104   GigabitEthernet1/0/28
--More--                           00:1C:23:45:A5:31   10.65.7.58       155600      dhcp-snooping   104   GigabitEthernet1/0/25
--More--                           B4:B0:17:98:E2:9C   10.65.107.148    591829      dhcp-snooping   204   FastEthernet7/0/43
--More--                           B4:B0:17:89:7E:96   10.65.107.65     618413      dhcp-snooping   204   FastEthernet8/0/43
--More--                           B4:B0:17:89:7E:CA   10.65.107.17     529433      dhcp-snooping   204   FastEthernet6/0/29
--More--                           C4:2C:03:1A:EC:CB   10.65.7.185      516333      dhcp-snooping   104   GigabitEthernet2/0/12
--More--                           A4:BA:DB:DD:FC:EA   10.65.7.100      679899      dhcp-snooping   104   GigabitEthernet4/0/17
--More--                           00:1B:4F:71:C5:DF   10.65.107.142    441142      dhcp-snooping   204   GigabitEthernet5/0/39
--More--                           00:1B:4F:4E:4F:64   10.65.107.131    680304      dhcp-snooping   204   FastEthernet8/0/37
--More--                           BC:30:5B:9E:D9:F7   10.65.7.95       678468      dhcp-snooping   104   GigabitEthernet4/0/36
--More--                           B4:B0:17:89:7E:84   10.65.107.33     624328      dhcp-snooping   204   FastEthernet8/0/41
--More--                           00:21:70:A4:A9:55   10.65.7.52       522375      dhcp-snooping   104   GigabitEthernet4/0/44
--More--                           00:18:8B:CE:C2:0F   101.100.100.172  72572       dhcp-snooping   129   GigabitEthernet2/0/28
--More--                           F0:4D:A2:FB:C2:EC   10.65.7.54       678043      dhcp-snooping   104   GigabitEthernet4/0/10
--More--                           B4:B0:17:8E:38:70   10.65.107.126    356771      dhcp-snooping   204   GigabitEthernet5/0/28
--More--                           5C:26:0A:4D:36:1A   10.65.7.164      620768      dhcp-snooping   104   GigabitEthernet4/0/42
--More--                           00:00:AA:87:90:36   10.65.32.10      593793      dhcp-snooping   115   GigabitEthernet2/0/47
--More--                           B4:B0:17:8E:38:3A   10.65.107.121    627435      dhcp-snooping   204   GigabitEthernet5/0/21
--More--                           B4:B0:17:8E:38:69   10.65.107.99     529816      dhcp-snooping   204   GigabitEthernet5/0/1
--More--                           B4:B0:17:89:7E:D0   10.65.107.93     506050      dhcp-snooping   204   FastEthernet7/0/4
--More--                           00:18:8B:DC:B9:16   10.65.150.9      156901      dhcp-snooping   997   GigabitEthernet3/0/27
--More--                           B4:B0:17:89:7E:6C   10.65.107.6      601743      dhcp-snooping   204   FastEthernet8/0/28
--More--                           F0:4D:A2:F9:9E:D3   10.65.7.8        675913      dhcp-snooping   104   GigabitEthernet3/0/8
--More--                           78:2B:CB:CA:A7:C0   10.65.7.59       535945      dhcp-snooping   104   GigabitEthernet2/0/7
--More--                           00:18:8B:05:1F:AB   10.65.7.57       678803      dhcp-snooping   104   GigabitEthernet1/0/11
--More--                           B4:B0:17:89:7E:87   10.65.107.19     438006      dhcp-snooping   204   FastEthernet6/0/27
--More--                           B4:B0:17:8E:0D:61   10.65.107.112    624396      dhcp-snooping   204   FastEthernet8/0/5
--More--                           B4:B0:17:8E:37:A1   10.65.107.94     686338      dhcp-snooping   204   FastEthernet7/0/3
--More--                           78:2B:CB:CB:F5:95   101.100.100.73   72155       dhcp-snooping   129   GigabitEthernet2/0/25
--More--                           00:15:C5:39:8B:08   10.65.7.121      678118      dhcp-snooping   104   GigabitEthernet4/0/16
--More--                           B4:B0:17:89:7E:AE   10.65.107.13     613430      dhcp-snooping   204   FastEthernet6/0/33
--More--                           00:1C:23:39:7F:AA   10.65.150.1      151863      dhcp-snooping   997   GigabitEthernet3/0/33
--More--                           00:24:E8:C0:37:EA   10.65.150.24     168267      dhcp-snooping   997   GigabitEthernet4/0/39
--More--                           00:1D:09:22:E1:22   10.65.7.149      570959      dhcp-snooping   104   GigabitEthernet2/0/19
--More--                           00:1E:C9:2D:DE:D3   10.65.7.91       678693      dhcp-snooping   104   GigabitEthernet2/0/21
--More--                           B4:B0:17:8E:37:94   10.65.107.98     641976      dhcp-snooping   204   FastEthernet8/0/6
--More--                           BC:30:5B:AD:25:98   10.65.7.85       680300      dhcp-snooping   104   GigabitEthernet3/0/3
--More--                           00:1C:23:0E:E0:E6   10.65.150.50     160810      dhcp-snooping   997   GigabitEthernet2/0/32
--More--                           B4:B0:17:8E:38:5E   10.65.107.3      527073      dhcp-snooping   204   FastEthernet8/0/30
--More--                           00:21:70:A4:A9:D6   10.65.7.66       679268      dhcp-snooping   104   GigabitEthernet1/0/22
--More--                           B4:B0:17:8E:37:8C   10.65.107.57     601392      dhcp-snooping   204   FastEthernet7/0/35
--More--                           F0:4D:A2:89:68:FF   10.65.7.30       598151      dhcp-snooping   104   GigabitEthernet3/0/4
--More--                           B4:B0:17:8E:0D:3D   10.65.107.116    626563      dhcp-snooping   204   GigabitEthernet5/0/16
--More--                           00:15:C5:44:1C:19   10.65.7.50       71286       dhcp-snooping   104   GigabitEthernet3/0/27
--More--                           B8:AC:6F:CB:1F:97   10.65.150.18     161835      dhcp-snooping   997   GigabitEthernet1/0/5
--More--                           00:1C:23:1C:05:90   10.65.7.15       679316      dhcp-snooping   104   GigabitEthernet3/0/31
--More--                           00:21:70:A4:FA:B9   10.65.7.98       678796      dhcp-snooping   104   GigabitEthernet4/0/2
--More--                           B4:B0:17:8E:0D:B6   10.65.107.150    509759      dhcp-snooping   204   FastEthernet6/0/17
--More--                           B4:B0:17:8E:0D:6A   10.65.107.77     351694      dhcp-snooping   204   FastEthernet6/0/16
--More--                           00:1E:37:18:9B:84   10.65.150.63     74450       dhcp-snooping   997   GigabitEthernet2/0/26
--More--                           B8:AC:6F:C8:F6:AE   10.65.150.47     97354       dhcp-snooping   997   GigabitEthernet1/0/40
--More--                           00:1A:A0:37:F5:3A   10.65.7.180      685078      dhcp-snooping   104   GigabitEthernet4/0/24
--More--                           00:1E:C9:44:1A:A8   10.65.7.45       678198      dhcp-snooping   104   GigabitEthernet3/0/10
--More--                           00:18:8B:DC:B9:16   10.65.7.150      589004      dhcp-snooping   104   GigabitEthernet3/0/27
--More--                           B4:B0:17:89:7E:9F   10.65.107.68     605727      dhcp-snooping   204   FastEthernet6/0/43
--More--                           B4:B0:17:98:E2:A8   10.65.107.25     601004      dhcp-snooping   204   FastEthernet7/0/25
--More--                           00:23:18:ED:9C:4B   10.65.150.70     105854      dhcp-snooping   997   GigabitEthernet4/0/46
--More--                           00:23:AE:A8:2B:5F   10.65.150.5      148077      dhcp-snooping   997   GigabitEthernet1/0/35
--More--                           A4:BA:DB:DD:F4:02   10.65.7.75       679127      dhcp-snooping   104   GigabitEthernet3/0/23
--More--                           B4:B0:17:8E:37:DC   10.65.107.107    352511      dhcp-snooping   204   FastEthernet7/0/14
--More--                           00:1C:23:30:04:8D   10.65.7.47       596160      dhcp-snooping   104   GigabitEthernet1/0/36
--More--                           00:20:6B:64:0C:14   10.65.32.103     438477      dhcp-snooping   115   GigabitEthernet3/0/47
--More--                           00:1B:4F:71:C3:1F   10.65.107.130    621886      dhcp-snooping   204   GigabitEthernet5/0/11
--More--                           B4:B0:17:89:7E:3C   10.65.107.43     440758      dhcp-snooping   204   FastEthernet7/0/31
--More--                           B4:B0:17:89:7E:76   10.65.107.18     507362      dhcp-snooping   204   FastEthernet6/0/28
--More--                           00:21:70:F4:8C:39   10.65.7.38       682331      dhcp-snooping   104   GigabitEthernet1/0/29
--More--                           00:1B:4F:71:C3:00   10.65.107.154    367585      dhcp-snooping   204   FastEthernet6/0/46
--More--                           F0:4D:A2:C1:9E:8C   10.65.7.128      675567      dhcp-snooping   104   GigabitEthernet4/0/11
--More--                           B4:B0:17:89:7E:98   10.65.107.16     604116      dhcp-snooping   204   FastEthernet6/0/30
--More--                           B4:B0:17:89:7E:62   10.65.107.38     592811      dhcp-snooping   204   FastEthernet7/0/32
--More--                           A4:BA:DB:DD:FC:EA   101.100.100.165  71084       dhcp-snooping   129   GigabitEthernet4/0/17
--More--                           00:1D:09:00:69:3A   10.65.7.175      684947      dhcp-snooping   104   GigabitEthernet4/0/24
--More--                           B8:AC:6F:CB:1F:97   10.65.7.123      677812      dhcp-snooping   104   GigabitEthernet1/0/5
--More--                           B4:B0:17:8E:37:BE   10.65.107.30     507304      dhcp-snooping   204   FastEthernet6/0/28
--More--                           5C:26:0A:53:FE:88   101.100.100.180  72581       dhcp-snooping   129   GigabitEthernet4/0/15
--More--                           00:21:9B:5F:F3:71   10.65.150.41     94187       dhcp-snooping   997   GigabitEthernet1/0/37
--More--                           B4:B0:17:8E:38:7F   10.65.107.110    615708      dhcp-snooping   204   FastEthernet8/0/3
--More--                           B4:B0:17:89:7E:BB   10.65.107.86     350515      dhcp-snooping   204   FastEthernet8/0/9
--More--                           B4:B0:17:8E:38:5A   10.65.107.115    625165      dhcp-snooping   204   FastEthernet8/0/13
--More--                           F0:4D:A2:89:62:8C   10.65.7.126      680934      dhcp-snooping   104   GigabitEthernet4/0/43
--More--                           00:21:9B:5F:F3:71   10.65.7.140      430017      dhcp-snooping   104   GigabitEthernet1/0/37
--More--                           00:24:E8:98:1F:33   10.65.7.107      596904      dhcp-snooping   104   GigabitEthernet4/0/28
--More--                           00:1E:C9:50:03:72   10.65.7.119      677533      dhcp-snooping   104   GigabitEthernet3/0/22
--More--                           00:24:E8:9A:B9:6E   10.65.7.117      602196      dhcp-snooping   104   GigabitEthernet4/0/32
--More--                           00:26:B9:BE:8B:74   10.65.7.36       686987      dhcp-snooping   104   GigabitEthernet4/0/12
--More--                           B4:B0:17:89:7E:4C   10.65.107.41     593772      dhcp-snooping   204   FastEthernet6/0/2
--More--                           B8:AC:6F:CB:1F:97   101.100.100.31   72993       dhcp-snooping   129   GigabitEthernet1/0/5
--More--                           00:1D:09:00:80:87   10.65.7.86       520722      dhcp-snooping   104   GigabitEthernet2/0/22
--More--                           BC:30:5B:9E:DB:42   10.65.150.57     72295       dhcp-snooping   997   GigabitEthernet1/0/27
--More--                           B8:AC:6F:49:C7:16   10.65.150.15     151584      dhcp-snooping   997   GigabitEthernet3/0/41
--More--                           00:24:E8:CF:B6:68   10.65.7.139      544784      dhcp-snooping   104   GigabitEthernet1/0/36
--More--                           B4:B0:17:8E:0D:85   10.65.107.52     530201      dhcp-snooping   204   FastEthernet6/0/26
--More--                           00:21:70:F4:7B:CC   101.100.100.240  3887        dhcp-snooping   129   GigabitEthernet3/0/24
--More--                           F0:4D:A2:FB:BE:23   10.65.7.51       590476      dhcp-snooping   104   GigabitEthernet4/0/19
--More--                           F0:4D:A2:B1:BE:23   10.65.7.65       681099      dhcp-snooping   104   GigabitEthernet2/0/14
--More--                           34:15:9E:06:F9:98   10.65.7.110      672487      dhcp-snooping   104   GigabitEthernet3/0/18
--More--                           00:1C:23:04:04:74   10.65.7.19       430542      dhcp-snooping   104   GigabitEthernet1/0/10
--More--                           00:1A:A0:22:AE:C7   10.65.7.92       589740      dhcp-snooping   104   GigabitEthernet3/0/6
--More--                           A4:BA:DB:DD:F3:FB   101.100.100.42   75339       dhcp-snooping   129   GigabitEthernet2/0/30
--More--                           A4:BA:DB:DD:F3:FB   10.65.150.29     169067      dhcp-snooping   997   GigabitEthernet4/0/46
--More--                           B4:B0:17:89:7E:90   10.65.107.78     447743      dhcp-snooping   204   FastEthernet7/0/13
--More--                           5C:26:0A:5F:72:0F   10.65.150.49     91941       dhcp-snooping   997   GigabitEthernet1/0/6
--More--                           00:26:B9:B2:E6:C6   10.65.7.137      676022      dhcp-snooping   104   GigabitEthernet3/0/25
--More--                           B4:B0:17:89:7E:37   10.65.107.48     593101      dhcp-snooping   204   FastEthernet8/0/35
--More--                           00:1B:4F:71:C3:22   10.65.107.139    521470      dhcp-snooping   204   GigabitEthernet1/0/48
--More--                           00:20:6B:64:0C:22   10.65.32.109     421346      dhcp-snooping   115   GigabitEthernet1/0/47
--More--                           00:21:70:94:91:C8   10.65.150.17     163548      dhcp-snooping   997   GigabitEthernet3/0/43
--More--                           00:1D:09:05:B9:F5   10.65.7.159      167030      dhcp-snooping   104   GigabitEthernet2/0/37
--More--                           00:1B:4F:55:42:E4   10.65.107.97     423481      dhcp-snooping   204   FastEthernet6/0/4
--More--                           00:0C:29:A6:4A:BF   10.65.150.55     157745      dhcp-snooping   997   GigabitEthernet3/0/26
--More--                           00:18:8B:BF:04:42   10.65.7.114      679999      dhcp-snooping   104   GigabitEthernet2/0/10
--More--                           B8:AC:6F:C8:F6:AE   10.65.7.63       623871      dhcp-snooping   104   GigabitEthernet1/0/40
--More--                           00:18:8B:A8:29:30   10.65.7.124      679484      dhcp-snooping   104   GigabitEthernet4/0/40
--More--                           F0:4D:A2:96:C5:1B   10.65.7.17       667919      dhcp-snooping   104   GigabitEthernet3/0/40
--More--                           5C:26:0A:38:65:5A   10.65.7.112      678296      dhcp-snooping   104   GigabitEthernet3/0/39
--More--                           00:18:8B:CE:C2:0F   10.65.7.42       438106      dhcp-snooping   104   GigabitEthernet2/0/28
--More--                           00:1E:C9:45:EE:E4   10.65.7.154      428312      dhcp-snooping   104   GigabitEthernet1/0/34
--More--                           B4:B0:17:8E:0C:77   10.65.107.141    357534      dhcp-snooping   204   FastEthernet6/0/48
--More--                           B4:B0:17:89:7E:29   10.65.107.46     446591      dhcp-snooping   204   FastEthernet7/0/17
--More--                           B4:B0:17:8E:0D:A4   10.65.107.118    612512      dhcp-snooping   204   GigabitEthernet5/0/18
--More--                           B4:B0:17:89:7E:64   10.65.107.40     683106      dhcp-snooping   204   FastEthernet8/0/26
--More--                           A4:BA:DB:DD:F3:FB   10.65.7.146      680144      dhcp-snooping   104   GigabitEthernet2/0/30
--More--                           5C:26:0A:75:D8:B6   10.65.7.144      688242      dhcp-snooping   104   GigabitEthernet1/0/15
--More--                           00:1B:4F:71:C3:26   10.65.107.143    356758      dhcp-snooping   204   GigabitEthernet2/0/48
--More--                           B4:B0:17:8E:0C:7B   10.65.107.45     670789      dhcp-snooping   204   FastEthernet7/0/5
--More--                           A4:BA:DB:DD:F4:16   10.65.7.68       534054      dhcp-snooping   104   GigabitEthernet2/0/9
--More--                           B4:B0:17:98:E3:53   10.65.107.156    453552      dhcp-snooping   204   FastEthernet7/0/20
--More--                           00:1E:C9:4F:C8:11   10.65.7.82       677845      dhcp-snooping   104   GigabitEthernet3/0/15
--More--                           90:E6:BA:85:F1:0C   10.65.150.73     79978       dhcp-snooping   997   GigabitEthernet4/0/21
--More--                           00:1E:C9:50:03:46   10.65.150.26     161447      dhcp-snooping   997   GigabitEthernet1/0/13
--More--                           78:2B:CB:E9:9C:C1   10.65.7.35       452140      dhcp-snooping   104   GigabitEthernet1/0/1
--More--                           F0:4D:A2:FB:C2:69   10.65.7.64       678155      dhcp-snooping   104   GigabitEthernet3/0/5
--More--                           00:26:B9:C2:D8:82   10.65.7.70       498683      dhcp-snooping   104   GigabitEthernet1/0/44
--More--                           B4:B0:17:8E:38:7C   10.65.107.85     447937      dhcp-snooping   204   FastEthernet8/0/14
--More--                           B4:B0:17:89:7E:B1   10.65.107.59     594195      dhcp-snooping   204   FastEthernet8/0/25
--More--                           00:12:3F:17:A7:88   10.65.7.161      608180      dhcp-snooping   104   GigabitEthernet1/0/4
--More--                           F0:4D:A2:FB:BD:FB   10.65.7.134      436867      dhcp-snooping   104   GigabitEthernet3/0/34
--More--                           00:1C:23:2C:C2:23   10.65.7.89       679210      dhcp-snooping   104   GigabitEthernet2/0/34
--More--                           B8:AC:6F:C6:75:A8   10.65.150.3      150184      dhcp-snooping   997   GigabitEthernet1/0/39
--More--                           00:1C:23:4D:88:15   10.65.7.125      593961      dhcp-snooping   104   GigabitEthernet4/0/30
--More--                           B4:B0:17:8E:0D:A7   10.65.107.34     523405      dhcp-snooping   204   FastEthernet6/0/13
--More--                           B4:B0:17:8E:0D:A5   10.65.107.61     516029      dhcp-snooping   204   FastEthernet6/0/18
--More--                           F0:DE:F1:68:C8:23   10.65.150.38     164330      dhcp-snooping   997   GigabitEthernet2/0/41
Total number of bindings: 392
so dhcp snooping is not enabled for this VLAN but DAI is ?
Can you enable  dhcp snooping for this vlan and sees if it is still happening.
Regards.
Alain.
Hello Alain
Hope ur weekend was great!
Which vlan u mean? If vlan 1, I think dhcp snooping wax enabled  see below:
sho clock
14:41:25.298 ETE Mon Oct 24 2011
Switch# sh ip dhcp snooping
Switch DHCP snooping is enabled
DHCP snooping is configured on following VLANs:
1-4094
DHCP snooping is operational on following VLANs:
1,10,100-108,110-129,202-213,985-999
DHCP snooping is configured on the following L3 Interfaces:
Insertion of option 82 is disabled
   circuit-id default format: vlan-mod-port
   remote-id: fcfb.fb6c.1980 (MAC)
Option 82 on untrusted port is not allowed
Verification of hwaddr field is enabled
Verification of giaddr field is enabled
DHCP snooping trust/rate is configured on the following Interfaces:
Interface                  Trusted    Allow option    Rate limit (pps)
TenGigabitEthernet1/0/1    yes        yes             unlimited
  Custom circuit-ids:
TenGigabitEthernet2/0/1    yes        yes             unlimited
  Custom circuit-ids:
TenGigabitEthernet2/0/2    yes        yes             unlimited
  Custom circuit-ids:
Waiting ur advice.
regards
Alioune
