ASA 5505 Firewall not enough space error
eberg0001
I'm getting an error on my ASA when uploading with tftp.. I'm trying to upload a new version of anyconnect and it's telling me there isn't enough space and then errors out.
The ASA currently has 69771264 bytes free and the anyconnect.pkg i'm trying to upload is 38360451 bytes.. Is this because it's a .pkg that it's not showing me the accurate space it's actually going to take up once uploaded to the ASA or what's going on here??
Any help would be great.
Thank you,
Eric
Pageplayer
Looks like you only have a little over 69MB left.. What is the total size of your memory? Cisco recommends you have 512MB total for your ASA..
You can read the info I found here:
http://www.cisco.com/c/en/us/td/docs/security/vpn_client/anyconnect/anyconnect30/release/notes/anyconnect30rn.html
If you have less then 512MB, Search ebay for a compatible memory
Hope this helps.
Okay that makes sense for the memory and it should be at 512mb for the ASA.. I do have another questions.. If I start to issue another SSL VPN and perform these steps seen here
http://www.techrepublic.com/blog/data-center/eight-easy-steps-to-cisco-asa-remote-access-setup/
Will that mess up my previous SSL VPN set up with anyconnect? Also how can I tell when that cert expires on the ASA CLI?
Thank you
I'm far from knowing the answer to this question. Post it on Spiceworks . com and I bet someone over there can answer it.
Chuck
