Data VLAN 192.168.3.0
Voice VLAN 10.50.50.0
DHCP Server with both ranges is 192.168.3.201
Gateway Linksys: 192.168.3.254
Switch configuration: -
AP Configuration
The above is working well but I want to introduce an ASA and remove the Linksys, my ASA only has 3 VLAN's with the key I have, so VLAN 1, 2 and 3
So my question to the experts here is "how do I introduce it with my current config?"
Thanks for your time
Martyn
You actually only have 2.5 VLANs with the 5505. If you use the .5 vlan it has to restrict traffic flow to 1 of the vlans.
Also you can create additional vlans but you can not associate them with access-list or NATing.
You have a couple options.
1) You buy a 5510
2) you use the following setup
WAN = vlan 2 (default for asa5505 -- from memory)
LAN = vlan 1 (aslo default for asa5505 -- from memory)
VOIP = vlan 3 (you will create this)
When you create the VOIP vlan you will choose to restrict flow to VLAN 1 (LAN). If you have a call manager then you will need to place the call manager server in vlan 3 with the VOIP. When you need to access the call manager just plug into a vlan3 port or change a port to vlan 3 for a short period of time.
Cisco is currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
If you have an ASA 5505 with base license, you have the INSIDE and OUTSIDE interfaces and a DMZ (with limited access to only another interface).
If you purchase a Security Plus license, then you will have 3 fully usable and routable interfaces on the 5505.
Federico.
