01-24-2014 12:44 PM - edited 03-10-2019 12:25 PM
hi all ,
just simple question
assume i have inside==ASA====outside========intnet
assume outside public ip is x.x.x.x
asusme i made a portforward on outside interface ,
assume my lan is 10.10.10.0/24
assume to reach my server 10.10.10.2 i need to go x.x.x.x:5050
the question is about the access rule that need to be allow the outside traffic that comes inside .
why i need to allow destination to ip 10.10.10.2 in the access rule ???
shouldnt we allow the access to x.x.x.x:5050 ip ???
question agian ,
why we need access rule that allow traffic that enter form outside to inside , and dont need rule to allow traffic enter outside ip itself ?
regards
Solved! Go to Solution.
01-26-2014 02:27 AM
For traffic to the ASA interface No.
For SSH, Telnet or any other device behind the ASA: Yes.
Please rate all of the posts that you think were useful for you
Looking for some Networking Assistance?
Contact me directly at jcarvaja@laguiadelnetworking.com
I will fix your problem ASAP.
Cheers,
Julio Carvajal Segura
http://laguiadelnetworking.com
01-26-2014 02:33 AM
well ,
at this point , its very fine
the question is why i cant login to the asa asdm remotely from the outside interface ???
i did config so that it support http
http server enable 65000
http 10.66.12.0 255.255.255.0 ins
http 0.0.0.0 0.0.0.0 outside
also ,
i can see the https webpage of asa asdm
but i cant login from the asdm itself !!
want to tell you that i chanfes the port of asa to 65000
here is when i put the public ip x.x.x.x:65000 on page
im being redirected to
https://x.x.x.x:65000/admin/public/index.html
but why on the asdm i cant login ??
it says ""connecting "" and not logged !!!
i tried to put the ip in the asdm with x.x.x.x & x.x.x.x:65000
but still no luck
01-26-2014 02:37 AM
Hello
can you share
show run asdm
show run http
show run aaa
show run all ssl
show flash | include asdm
show run webvpn
Cheers,
01-26-2014 02:53 AM
hi , currently i dont have an access on asa ,
but i have the sh run file
here wt u need
asdm image disk0:/asdm-645.bin
aaa authentication http console LOCAL
destination transport-method http
aaa authentication ssh console LOCAL
agian , i can log by vpn , but still cant access asa asdm from vpn !!!!
