ASA Load balance Question
tbarberio
On a cisco ASA is it possible to load balance between 2 ISP links? Or is that not supported.
Basically have an ASA load balance MPLS connections or is this not going to work and they have to use a router? meaning want both MPLS connections active for LB and redundancy in case ones fails. Can this be accomplishes in ASA devices or have to go to a router for this?
If not possible in an ASA can I make one of the links NON active for auto failover i realize then I would have no LB but at least some redundancy.
ALIAOF_
Level 6
Level 6
Ok this was very helpful
But 2 questions remain after reading both.
1. If isp#1 fails will it faill all traffic over to ISp#2?
2. Will the workaround in doc15622 only work below a certain code version?
Abzal
Level 7
Level 7
As far I know ASA does not support load balancing but I'm not sure about the latest versions.
https://supportforums.cisco.com/thread/2050087
I think it's better to use routers instead of ASA.
Sent from Cisco Technical Support Android App
Best regards,
Abzal
