ASA5510 failover setup
SOL10
hi there, im trying to setup failover between two ASA 5510 and on inter e0/3 (on both ASA's) i have plugged a crossover a cable directly connecting them. Will this work to configure LAN based failover with stateful failover or do I need to connect the 2 asa's with a serial cable?
andrew.prince
Level 10
Level 10
The below URL will be able to point you in the right direction, as there are a few answers to your question!
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml#conf
HTH.
andrew, thanks for the reply but having read that and looking at the diagram, it uses a serial cable and does not mention that straigh through ethernet cable can be used.
jcoke
Level 3
Level 3
As there's no serial port on the ASA 5500 series appliances, you'll need to follow the LAN-based failover instructions in the Configuring Failover chapter of the Cisco Security Appliance Command Line Configuration Guide
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/failover.html
