ASAv and OSPF
shorea50
Hi All,
I have an odd issue with OSPF and ASAv.
If i create 3 ASAv's in serial I can get OSPF up and working with no problem routes pass all the way along.
If I try to connect a physical switch/router or an NSX edge device I get a very odd issue.
The neigbour adjacency forms, the routes are passed to the ASAv but after a minute the ASAv loses the routes.
If I show (ip) ospf neighbour on the router/switch it shows the state as full but the ASAv shows it as loading and it stays in this state until I clear the OSPF process on the ASAv. I've checked every option and setting  can think of but nothing seems to fix it. I've change priority to make the ASAv BDR and DR no difference.
The ASAv is running version 9.3
Everything else in the network works perfectly.
Any idea welcome.
0 Replies 0
