ASR 1000 series router upgrade path
philhenson
I am upgrading an  ASR1002 to "asr1000rp1-adventerprisek9.03.16.05.S.155-3.S5-ext.bin" from "asr1000rp1-adventerprisek9.03.05.01.s.152-1.s1.bin". [from 15.2 to 15.5] Is there an upgrade path to get from this very old version to the latest?
Can I go straight to the latest in one try?
Thank you.
Phil Henson
Reza Sharifi
It doesn't appear that there is an upgrade path.  You can go directly from 15.2 to 15.2 using the consolidated software package and a maintenance window to reboot.
Here are a couple of links for upgrade instructions and release notes:
http://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/asr1000-software-config-guide/pkg-mgmt-asr.html#con_1057891
http://www.cisco.com/c/en/us/td/docs/routers/asr1000/release/notes/asr1k_rn_rel_notes/asr1k_rn_intro.html
Leo Laohoo
You can go straight.
Don't forget to upgrade the ROMmon.
