08-16-2018 12:32 AM - edited 03-08-2019 03:55 PM
Hello
I start a 60-day temporary license for 10g interface
Licensing expired in a few hours ( 24 hours )
A permanent license has been ordered and will take several weeks
what happen in
How can I activate a temporary license again? I have no problem deleting / restarting the router ?
Changing date and time did not solved problem .
What happens to the interface after licensing ends? Does it stop working or can not change?
Index: 8 Feature: interface_10g Version: 1.0
License Type: EvalRightToUse
License State: Active, In Use
Evaluation total period: 8 weeks 4 days
Evaluation period left: 1 day 0 hour
Period used: 8 weeks 2 days
Transition date: Aug 17 2018 10:50:40
License Count: 2/0 (In-use/Violation)
License Priority: Low
Store Index: 13
Store Name: Built-In License Storage
reagard
gadi
08-16-2018 01:37 AM
don't reload the router. When the evaluation license expires, nothing will happen and everything will continue to function, but you are legally required to purchase a permanent license.
If you reload the device, it will default to whatever license was installed before the evaluation license was enabled...which in your case was probably nothing at all. You cannot reactivate the evaluation license by reloading the router...
08-16-2018 06:14 AM
08-16-2018 06:38 AM
In addition to what others said, the license usually applies to the whole router (I know it is this way for 1002x) and not just the 10Gig interface. So, as long as the box has a permanent license, you should be good to go. Also, if you issue "sh lice" and you see something like this, you should be fine
Feature: adventerprise
Period left: Life time
License Type: Permanent
