ASR1000 series etherchannel
pajams
I tried several methods to do etherchannel on the ASR1006 to 3750 switch.
Method one:
port-channel 1
ip add 10.10.10.2 255.255.255.0
int g1/0/51
no switch
channel-group 1
ASR1006 configuration
int port-channel 1
ip add 10.10.10.1 255.255.255.0
int G2/1/0
channel-group 1
the port channel would show up but would not negotiate. Could not ping other end.
Other method
Switch config
vlan 2
g1/0/51
switch
switch trunk encap dot1q
switch trunk allow vlan 2
switch mode trunk
ASR 1006 configuration
int g2/1/0
vlan-id 2
this sets up subinterface and the example does no go from there. The router will not let you set up different encapsulations on the sub-interface.
I need a clear example to have two one gig connections from a 3750 switch to an ASR1006 to form a two gig etherchannel
Giuseppe Larosa
see the following document ASR1000 is different then other devices about etherchannel
http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/lsw_cfg_gecvlan_ps9587_TSD_Products_Configuration_Guide_Chapter.html
it uses subifs and has the concept of vlan mappings that is different from what we are used to see on switches
if you want to use it for a single vlan it will use a single GE (this was described in another thread)
Hope to help
Giuseppe
